EL header to up pipe condensation leak? HELP!!!
Old May 22, 2015 | 02:21 PM
bmxhotsauce's Avatar
Car Info: subaru
guys,
i just changed out my header and up pipe gaskets.
at cold starts i have a small amount on condensation that leaks from my header where it meets my up pipe. its not coolant for sure but its a little hard to smell. so i know its not E85. i do not have any fuel leaks. maybe just a bad gasket? there is not a exhaust leak either.
has anyone else experienced this before ?
maybe a new gasket or or some type of hi temp sealant i can use?
thank you guys
Old May 22, 2015 | 05:12 PM
oaklandish_WRX's Avatar
Car Info: 0[[XXXXoXXXX]]0
Fluid color? Pics may help. Mods list (you mentioned E85, so your not stock...)?
Can you capture some on a clean paper towel and smell, etc.?
you don't need sealant, you need to find out where this fluid is coming from. Could be coolant from the oil cooler right there by the manifold and UP.
Old May 25, 2015 | 07:38 PM
Car Info: subaru
It looks and smells like water. The fluid is clear. I changed my coolant to the new subaru blue coolant so I know it's not coolant at all.
Old May 25, 2015 | 08:40 PM
Rev. Rob Large's Avatar
Call me Pebbles
Car Info: Moist
Either the flanges aren't sealed (bent flange and/or poorly seated gasket) or there is a crack in either the pipes or welds at the flanges.
Old May 26, 2015 | 10:09 AM
Car Info: subaru
thank you i will look into this.
i ordered a new gasket. i never had this issue below with my set up. i do not see any cracks at all. i know sitting over night might blow up some condensation but shouldn't leak from the header to up pipe.
thank you guys. i do not see any other issues. no exhaust leak or boost issues at all
Old May 26, 2015 | 01:33 PM
vaj's Avatar
vaj
Car Info: 2004 Big Booty STi with a two finger gap.
If the flanges are true and the gasket is bueno then what I've found is that the order in which I tighten the connections makes a difference. This is typically what I do.
Mani- UP
UP-turbo
Mani-Heads
Good luck!
Old May 26, 2015 | 01:53 PM
Car Info: subaru
Mani- UP
UP-turbo
Mani-Heads
Good luck!
thank you. i would try that if i was going to replace all the gaskets again.
any order i should tighten down the head to up pipe? its simple i know i have done this many times before without an issue. so i hope its just a bad freak gasket.
WRXXX
Jul 15, 2005 11:59 PM
WarreX
Jul 3, 2005 11:30 AM
minisiu
Oct 22, 2004 03:26 PM
ScoobyRoo20
Sep 9, 2003 04:43 PM
bigdaddy
Jul 10, 2003 12:09 PM
