Dynoflash with FP HTA3586R on '05 STI
Old Oct 30, 2008 | 08:00 AM
Aniel@FP's Avatar
Car Info: EVO IX
Not sure how many of you guys have seen Al from Dynoflash and his STi check it out http://forums.evolutionm.net/showthread.php?t=377950
Old Oct 30, 2008 | 08:14 AM
meilers's Avatar
34 PSI through the EJ25 is a bomb waiting to go off.
Old Oct 30, 2008 | 08:54 AM
KOSTI's Avatar
Car Info: Black On Black Wingless 05 STI
bomb is right..
Old Oct 30, 2008 | 03:30 PM
ds baruuuuu's Avatar
Car Info: 5.4RS
if you read in his thread its not a stock motor he said its a built motor and trans
Old Oct 30, 2008 | 04:17 PM
kmurphy's Avatar
Car Info: 06 obp sti
he'll be just fine. The block is built with darton sleeves.
Old Oct 31, 2008 | 10:27 AM
Aniel@FP's Avatar
Car Info: EVO IX
Yea i dont think thats his first Rodeo
Old Oct 31, 2008 | 11:07 AM
meilers's Avatar
Oh, I know that. The issue at that PSI isn't rods or cylinder walls, it is the head gasket. The boxer motor configuration makes for an unusually large surface area for the head and crankshaft/cam gaskets; you can blow them with stock PSI (and with the EJ25 Legacy block, with NO added PSI). It is absolutely awesome to have that kind of power out of the EJ25, killer job on that -- but driving it more than 1/4 mile at a time -- yow! :-)
Old Oct 31, 2008 | 01:17 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Bah... I was running 30psi on a bone stock block and the head gasket held just fine
BTW, if you read the entire thread linked from here, there are some large discrepancies between the "comparison" and Al won't confirm or deny that he was running more boost with the HTA turbo. Take all this with a grain of salt.
Old Oct 31, 2008 | 01:33 PM
04caliwrx's Avatar
"dang bro" "hella fast Bro!" hey I'm Al. That guy blows up SO MANY car!
Old Oct 31, 2008 | 04:32 PM
Car Info: 5.4RS
i was kinda getting that but i think the biggest comparison he was making was that the fp turbo has a bigger wheel and still spools the same as a gt35....
i think
Old Oct 31, 2008 | 10:06 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
i think
Different fuel system, different boost levels, completely different weather... no real valid comparison there IMO. Also, if the bigger compressor wheel doesn't make significantly more power at the same boost level, what's the point of it being bigger?
Old Nov 1, 2008 | 08:58 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Can you clarify this part for me?
I do not know what a crankshaft/cam gasket is.
Old Nov 3, 2008 | 07:56 AM
meilers's Avatar
Sorry, I meant the valve cover gasket, my mind was wandering.
Old Nov 3, 2008 | 11:12 AM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
What a crazy guy!!!! I needz that turbo
thunder_sti
Aug 31, 2006 02:42 AM
thunder_sti
Aug 26, 2006 11:00 PM
