Does 05 STi have a factory oil cooler???
Old Jun 19, 2006 | 02:43 PM
BlackTzak's Avatar
Car Info: 2005 OBP STi
seems to be some mixed information I'm finding on this...
I know the spec c sti comes with an oil cooler but not sure that the 05+ STi comes with one.
Old Jun 19, 2006 | 10:38 PM
BlackTzak's Avatar
just found this link...
seems like perhaps only the spec c does??
http://www.j-garage.com/subaru/impreza/gdb/2005spec.htm
Old Jun 20, 2006 | 09:20 AM
BlackTzak's Avatar
Update from SOA...
All US STi's come with factory oil cooler.
Old Jun 20, 2006 | 10:21 PM
PA04STi's Avatar
Car Info: WRB 04 STi w/ Gold Wheels, BlitzSUS, TurboXS turbo back exhaust, Pink I, more to come
Yes there is a ring around your oil filter that ring is cooled by coolant to cool the oil.
Mine is an 04 STi
Old Jun 21, 2006 | 09:25 AM
lburrrna's Avatar
Talking
how about the 06 wrx?
Old Jun 21, 2006 | 01:42 PM
PA04STi's Avatar
Not sure check when you change your oil if your filter goes into a metal ring with coolant lines going into it then yes it does...
Old Jul 19, 2006 | 08:06 PM
matt2pnt5rs's Avatar
There is no oil cooler in the '06 WRX sorry guys. Also this is not an easy change if you go factory as the water pump housing has an extra fitting dedicated for use with the oil cooler which is not the same pump as on the wrx. Although there are many cheaper aftermarket alternatives with better results aside from going witht the $1,600 spec c cooler.
depdivr
Sep 29, 2005 10:52 PM
Kaos22B
Jul 24, 2004 01:45 PM
East Coast WRX
Oct 14, 2003 08:42 AM
Arkangelscooby
Jun 18, 2003 10:26 PM
