Do I have boost Creep in my STI?
Old May 23, 2005 | 08:22 PM
Sti"izzle"'s Avatar
Car Info: 06 Sti GST TUNED
Exclamation Do I have boost Creep in my STI?
I currently have a Helix Catted DP and Borla Hush Exhaust. I am running the Cobb Stage 2 program. I don't hear any weird sounds, and my boost gauge never goes higher than .11 boost? Is there anything that I need to worry about?
Old May 23, 2005 | 11:05 PM
slow04wrx's Avatar
Could you take a clip of your exhaust? Thanks I'm about to b uy that setup as soon as I finish getting the money.
Old May 23, 2005 | 11:30 PM
isr96's Avatar
Car Info: 2007 suzuki GSX-R600
are you holding consistant boost levels? have you ever hit fuel cut? do you see the boost hit a certain psi then drop and raise back up?
Old May 24, 2005 | 05:10 PM
Sti"izzle"'s Avatar
Fuel Cut?
From what I can tell, My boost stays pretty even. I don't seem to notice what feels like fuel shut off, would I easily notice it?
thanks,
B
Old May 24, 2005 | 07:00 PM
okpanic's Avatar
Car Info: 07 Silver Mazdaspeed 3
I have been encountering a similar problem. I am hitting the high boost from my cobb stage 2 but it sounds like my bov is leaking. most of the time the turbo tone is steady but in hard driving I notice a sound that seems to be the bov venting. as for your boost creep try (if you haven't already) changing the base map to what you want and not the realtime map.
Old May 24, 2005 | 10:21 PM
Sti"izzle"'s Avatar
Cobb Stage 2
I just put on 91 octane Base and Real map and put that on there. How would I do it differently? Also, wouldn't boost creep make a noticable knock or ping?
Old May 24, 2005 | 11:37 PM
isr96's Avatar
if you hit fuel cut...you will definately know it since it throws a CEL. It will have kinda a instant jolt feeling where it's resisting....plus scare the **** outta you. From what you describing, it sounds fine so no worries man.
Old May 25, 2005 | 03:04 AM
Yeah, boost creep is like female orgasms... if it happens, you KNOW. If you're not sure... keep trying.
Old May 25, 2005 | 07:37 AM
Sti"izzle"'s Avatar
Talking Awesome.
The STI must be for my pleasure only, because she isn't making any noticable sounds or screams!
Old May 25, 2005 | 09:01 AM
isr96's Avatar
haha in a way thats kinda right....if you wanna keep trying, do some freeway pulls starting at around 50 mph in 5th or 6th gear and keeping accelerating to see if it creeps.
Old May 25, 2005 | 09:03 AM
isr96's Avatar
your not trying hard enough
Cowboy7
Feb 5, 2007 07:20 AM
xicema17x
Oct 7, 2004 10:05 PM
619sti
Aug 1, 2004 03:44 PM
03WRX!!!
Jul 19, 2004 02:40 PM
stryfewrx
May 27, 2003 07:30 PM
