Danger in not having bellmouth DP?
Car Info: 2003 WR Blue WRX Sedan
I know having a downpipe with a divorced wastegate or bellmouth is preferable for better performance, but is there any DANGER in not having a bellmouth or divorced opening right after the turbo? Will there be an increase in pressure behind the turbo causing shorter life or engine failure??
Am I putting my car at risk by not having a bellmouth?
Thanks, Andy
Thanks, Andy
yeah no "risk" per se, only other than wasting your time/money on a dp that will give you minimal gains over stock that you will eventually be pulling out to replace with a better design
good used bellmouth DPs trade for under $200 nowadays, keep your eye out for one, you'll thank me!
con10der_8
Aug 26, 2014 09:23 PM
blackwagonrx
Feb 10, 2003 12:25 PM
