Compression Test Done.... is this bad?
Old Jul 25, 2007 | 08:03 AM
NorCalBugEye's Avatar
Car Info: 413whp/461wtq
#1 150
#2 150
#3 142
#4 150
the guys at Speed Element say it is still within spec, but im just wondering if there would be any significant damage down the line if I continue to mod?
oh and the car is a 04 STi with 38k miles.
Old Jul 25, 2007 | 08:53 AM
ipozestu's Avatar
Car Info: Broken Subarus
It's certainly showing some wear. Are you pretty much stock? Engine management?
Old Jul 25, 2007 | 09:14 AM
740cc injectors
wlabro fuel pump
custom tuned with Cobb Accessport
Old Jul 25, 2007 | 09:16 AM
yea Rob was telling me the #3 cylinder gets a lot hotter cuz of its location next to the turbo and thus gets more wear and tear than the others.
it originally was at 132 until Mike shot some oil into it and tinkered with it. now it is at 142. so im assuming there is something happening with the motor right now.
Old Jul 25, 2007 | 09:49 AM
ipozestu's Avatar
If it's on it's way out, drive it 'til it croaks. Buy a Cosworth you'll save money in the long run.
Old Jul 25, 2007 | 10:04 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Thats not blown....just a little worn. Still fine as long as its not pouring out smoke.
Old Jul 25, 2007 | 12:18 PM
yea no smoke but im gonna hold off on major mods for now. probably just gonna save up for a TBE and tune, and keep an eye on this.
Old Jul 25, 2007 | 09:32 PM
midnitewrx's Avatar
sure you be ok. just dont be dumb
Old Jul 26, 2007 | 10:10 AM
dont plan on being dumb, but i was planning on doing some track days/auto X. oh well, drive it till it blows i guess. no point in babying a car thats meant to be driven But i will definately be keeping an eye on the motor.
Old Jul 26, 2007 | 01:10 PM
meilers's Avatar
Oil consumption (> 1 qt per oil change period, for example) is a better indicator that you're in serious trouble than a slight change in a compression test. Your mechanic was totally right about cylinder 3, it is the achilles' heel of all turbo boxers.
Old Jul 26, 2007 | 04:34 PM
yea im not too worried about it as it is still in spec range, but oil consumption has been fine the whole time. change it regularly every 2500-3000
Old Jul 30, 2007 | 03:33 PM
NSM's Avatar
NSM
Car Info: '07 STi
The compression improvement you saw after adding oil may indicate ring sealing issues. I'm just learning the boxer motor, but that's what it would mean in a V8 where the piston is more vertical.
Old Jul 31, 2007 | 01:51 AM
NorCalDC5's Avatar
Car Info: 2016 FXT
How much did they charge for the compression test?
Old Nov 19, 2007 | 01:13 AM
Roundhead08's Avatar
Car Info: Subaru wrx
I would have done a leak down test also. Oil consumption is normally piston/oil ring issue coupled with white smoke on exhaust. You could possibly leaking on the valve seat also which will not show this symptoms.
Old Nov 19, 2007 | 09:19 PM
Shazam321's Avatar
compression with a leaky valve seat wouldn't go up when you put a lil oil in the cylinder. the oil basicly creates a temporary seal around the piston rings (tests to see if there is a broken piston ring), causing the compression to go up. Burning of oil will create a blueish color smoke. white is associated with burning of coolant(i.e. blown head gasket).
BattleD01
Jan 13, 2006 07:13 AM
midnightwrx
Jun 8, 2005 09:05 AM
JDM SiR
Mar 9, 2005 10:36 PM
IS2Scooby
Mar 26, 2003 09:41 PM
