Cobb Stage 2 Question
Old Oct 29, 2007 | 06:29 PM
bjielsl's Avatar
Car Info: 08' STI OBP
I am running the full Cobb Stage 2 TBE and APv1 with Stage II 93oct Map. I am hearing a whistling noise and I can not tell if it is the sound of the turbo.. cause it sounds like my girls 07 Mini Cooper S, or if I have an exhaust leak... I only hear after 2300 rpm.. I was hoping someone else had dealt with this...
Old Oct 29, 2007 | 06:53 PM
matthepcat's Avatar
Car Info: 2006 WRX wagon
Totally normal turbo spoolin' noise. You also prob. hear some wastegate noise as well.
Old Oct 29, 2007 | 07:27 PM
onechop's Avatar
Car Info: 06 sgm STI & 06 b9
Smile
I ride with the stereo off just to hear that lovely sound!!!!
Old Oct 29, 2007 | 08:24 PM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
90% is your turbo lol dont you love that sound?
Old Oct 29, 2007 | 08:34 PM
so steezy's Avatar
Car Info: *WiDe AnD LoW*
who needs music when your turbo sings to you...
I just realized how gay that sounded
Old Oct 30, 2007 | 07:35 AM
onechop's Avatar
lol
Old Oct 30, 2007 | 05:02 PM
Subistrong's Avatar
Car Info: 2006 subaru impreza wrx
anyone got the stage 2 cobb on their wrx 06-07?
Old Oct 30, 2007 | 05:36 PM
karis119's Avatar
Car Info: 05 STI
The easiest way to tell if it is an exhaust leak is have someone crawl underneath the car while your revving it and check all of the connections on the pipes. If you can feel air coming through the gap, then you have a leak. It may also have liquid dripping out too. Most likely the turbo, but checking the exhaust leak is fairly simple.
Old Oct 31, 2007 | 04:03 PM
bjielsl's Avatar
I am also hearing a sound between 3000-5000 rpm that sounds kinda like lifter clatter... is that the wastegate flutter I have been hearing about?
Old Nov 7, 2007 | 07:41 PM
bjielsl's Avatar
What does wastegate flutter sound like... I mean.. when I am pulling around 3000rpm with load (like up a hill) Its pretty loud
Old Nov 7, 2007 | 09:20 PM
it should be the turbo, around 3000RPM thats when the turbo is really kicking in. you will hear alot of spool.
Old Nov 7, 2007 | 10:58 PM
bjielsl's Avatar
It sounds like the lifter clatter I used to get in my truck
Old Nov 27, 2007 | 03:48 PM
jonjie320's Avatar
Car Info: 07 wrx
i had the same problem last week. turned out the gasket from the exhaust to the up pipe cracked. spent 30bucks to have it fixed.
srbaugust
15
Jun 2, 2013 02:02 AM
1FSTREX
Oct 2, 2007 07:22 AM
enzo350
Nov 3, 2006 07:49 AM
enzo350
Hawaii Classifieds
Nov 3, 2006 07:47 AM
casualsurfer
May 3, 2004 03:24 PM
