Cobb AccessPORT and Stage exhaust mods, '05 STi (was: Help Out)
Old Mar 6, 2006 | 11:53 AM
dyepball1's Avatar
Car Info: o5 esteaeye
Help Out
Ok, after searching the boards for a few days i tried to pull as much information as i could but i think it would just be eaisier to ask generaly so here it goes.
My major spring mods were going to be COBB AP and then short after up/dp, for my 05 STi
I have a few questions.
What power gains will i truly see?
What would be the best direction i should go in as far as most power and still being able to pass inspection without replacing to stock. (what catted pipes/ap capabilitys)?
Is COBB's Inconel625 uuppipe worth the extra 100?
Would eventualy getting the cat back be benificial?
Anything else i should know about this path?
Thanks a lot!!!
Old Mar 6, 2006 | 11:56 AM
SubyN00by's Avatar
you don't need to replace the uppipe.
the downpipe and a good catback or full turbo back exhaust will work great with the ap.
it's all about the tune too
Old Mar 6, 2006 | 12:15 PM
dyepball1's Avatar
I thought you needed the uppipe to run stage 2, if i only need the downpipe would it be ok to run stage 2 without the new catback?
Old Mar 7, 2006 | 07:17 PM
willz23's Avatar
Car Info: WRX STI
The sti's uppipe is already catless, so you don't need it to run stg. 2. You can run stg2 with only the downpipe, many people have done this, but it isn't reccommended. You will see high EGT's with only a downpipe for stage 2, it's probably better to get a full tbe.
Old Mar 8, 2006 | 07:40 PM
dyepball1's Avatar
why isnt it recomended, and what could i do to run stage two without the full tbe. Would it be ok to go with another companys dp to run the stage 2. Im low on money and im looking at the grouppe s stage one power packedge. Would that work at all or well running stage 2 on the ap
Old Mar 12, 2006 | 05:53 PM
dyepball1's Avatar
^^^^bump^^^^?
Old Mar 22, 2006 | 11:29 AM
dyepball1's Avatar
can someone at least tell me if i will pass emissions with just the street tbe, since i have decided to go fully cobb stage 2 but will not be reciving the ap for a few months.
Old Apr 11, 2006 | 11:46 AM
Island Style's Avatar
You will pass
emissions if you maintain a catted downpipe (one with a cat in it)...catted downpipes add about $150-$200 to the price of downpipe...but is necessary in areas such as yours...
I personally like the Cobb and PDE downpipes because they use the stock donut gasket...which prevent a lot of of exhaust leak problems...they do taper down to 2.5" though...
Lot's of exhausts to choose from...sound/performance...tailor it to your needs...
Old Apr 11, 2006 | 11:51 AM
scarface's Avatar
Car Info: 2005 WRX STI
I have a catless helix DP and a cobb access port with a custom dyno tune. Definately worth every penny. I have a Greddy SP2 CBE. Very nice setup and it is all about the tune!!!! Uppipe is not neccessary to replace on an 05 STi it is already catless. With anything catless in your system i believe you will not pass emissions but i could be wrong. But who cares its five years away!!!! Just put stock back in for a day and back to catless!
E
srbaugust
15
Jun 2, 2013 02:02 AM
bigbobchamp
Hawaii Classifieds
Nov 23, 2009 05:26 PM
Slack
13
Dec 16, 2004 07:06 PM
