clutch sqeaks when i let it out???
Old Aug 19, 2009 | 11:52 PM
toofast4u2's Avatar
Car Info: Black 2006 STI
Question clutch sqeaks when i let it out???
when i put the clutch in to shift it's fine, but when i let the clutch out and listen i can hear a squeak. what does this mean? u think it's covered under warranty?
Old Aug 20, 2009 | 06:50 PM
toofast4u2's Avatar
heard it could be clutch slave?
Old Aug 20, 2009 | 06:52 PM
VRT MBasile's Avatar
Is it loud enough that you hear it while driving? I can sometimes hear the parts moving when I let it out at a stop sign if my window is down and there is no ambient noise.
Old Aug 20, 2009 | 07:09 PM
ciRe_oNe's Avatar
Car Info: 2006 AW STi
This is happening to me as well. It mostly happens when its hot weather (90 degree +)
Old Aug 20, 2009 | 08:27 PM
SR20steve's Avatar
Car Info: Evo X GSR, F250 Powerstroke Diesel
I had this happen to me with my ACT 6 puck. At first it was ever so slightly only at engagement, just a slight squeal. But as time went on it got worse and would start rattling when I would turn the AC on (only at idle and in neutral). I assumed it was the TO bearing. When I had the new motor installed I was told my PP was shot and needed a new clutch.
Old Aug 20, 2009 | 08:35 PM
ciRe_oNe's Avatar
Mine is fine when AC on..Just makes a noise when its hot weather and 30mins of driving.
Old Aug 20, 2009 | 09:19 PM
SR20steve's Avatar
When mine first started going out it didn't make any noise beside when letting the clutch out so take it with a grain of salt. If the noise starts getting worse its probably the PP or TO bearing. Just be ready to replace the clutch its not a big deal, the clutch shouldn't be squealing.
Old Aug 20, 2009 | 09:22 PM
ciRe_oNe's Avatar
When that day does come I will opt for a lightweight fly wheel as well.
Salty
Sep 28, 2004 12:49 AM
gpatmac
May 2, 2004 01:11 PM
Mach5WRX
Jan 17, 2003 10:47 AM
