Check engine light & cruise control....
Old Jun 4, 2006 | 02:47 AM
wei8532's Avatar
Car Info: 04 STI
Unhappy Check engine light & cruise control....
Hi everyone.... I was driving on the highway today, and my check engine light comes up.. and my cruise control light start flashing.. does anyone know what's wrong with it???
Old Jun 4, 2006 | 02:59 AM
lburrrna's Avatar
wat mods do u have? wat have u done lately? from mods to driving habits. if u got an 06 is it a STI or WRX and how many Miles?
Old Jun 4, 2006 | 04:25 PM
wei8532's Avatar
Car Info: 04 STI
sorry, Mine is 04 STI.. I changed my intake.. also a cat back exhaust, that's it, also my car is around 50k....
Old Jun 5, 2006 | 08:14 PM
Peaty's Avatar
I'm pretty sure anytime you get a CEL when you have drive by wire it will flash the CC too. I think you may need the mechinical fix on the rear O2 sensor:
http://www.scoobymods.com/forums/showthread.php?t=5468
But w/o pulling the code it's hard to say for sure. Most AutoZones will pull the code for free.
Old Jun 5, 2006 | 10:41 PM
turtle-speed's Avatar
Car Info: 2004sti
Talking
Possible maf sensor or O2 sensor error . Need to check what code's being thrown to really know for sure . The check engine lite and cruise control is a feature to protect your car from being damaged more by limiting boost to a safe level , until you can get in to be serviced .
Old Jun 5, 2006 | 10:45 PM
Cody8675309's Avatar
Put your intake back to stock.
Old Jun 6, 2006 | 06:27 PM
wei8532's Avatar
Car Info: 04 STI
thx for the help guys!!~~
Old Jun 21, 2006 | 03:31 PM
chgabbs's Avatar
Car Info: 2006 WRX TR
My car gave me the same problem when I disconnected the return plumbing hose from the stock by-pass vavle. So I reconnected it and the CEL went away and cruise light stopped blinking. I bet they are right about it being the mass-air-flow sensor not liking your intake.
Old Jun 22, 2006 | 02:46 PM
SilencedImpreza's Avatar
Car Info: 06 TR
I believe that means you over boosted the turbo.. I did the samething in my wrx. I dont know for sure if it means the same on an sti tho.
SilencedImpreza
Old Jul 12, 2006 | 06:25 AM
dubwrx's Avatar
Car Info: 2004 STi
YES you overboosted. i think it is the 420something code. generally happens in cooler weather. happened to me also going to a race.
you can clear it with a CEL code reader or i believe you can disconnect your negative battery cable.
Old Jul 12, 2006 | 06:29 AM
Peaty's Avatar
I had that happen to me too when it was -4°F outside and I had to pass a car on the highway. Got the overboost code I also saw my max boost hold at around 18 PSI-G. Scared the heck out of me when it happened because the car shuddered when the CEL flashed but ran fine otherwise (plus the flashing CC lamp) cleared the overboost code and it was fine.
Racerkid
May 29, 2012 06:16 PM
Irish_car_B0mb
19
Jun 16, 2009 12:56 PM
Sharky
Mar 25, 2007 12:49 PM
06scooby
Oct 15, 2006 10:11 AM
splitsecond
Jul 31, 2005 02:39 AM
