Check engine light!!
Old Feb 16, 2013 | 06:25 PM
mendeeze's Avatar
Have an 05 sti with a check engine light sayin it's my gas cap but I replaced it and it still throws the code can anybody help
Old Feb 16, 2013 | 06:53 PM
Drew's rex's Avatar
Car Info: 2002
Check your EVAP Solenoid to see if all the hose connections are connected. If its not that, then its your purge valve located under the gas tank.
Old Feb 16, 2013 | 06:57 PM
Did you reset the ECU after putting the new cap on?
Old Feb 16, 2013 | 08:11 PM
Drew's rex's Avatar
Car Info: 2002
I'm assuming this is a P0457 OP? Do what chicken said, clear the code and see if it comes back. However, it wouldn't hurt to check the EVAP Solenoid for loose connections.
Old Feb 16, 2013 | 08:17 PM
mendeeze's Avatar
Yea I reset it then it came back also checked all hoses and everything looks good but haven't actually checked the solenoid itself thanks for the help guys really appreciate this **** is driving me nuts
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
