Car wont start help
Old 12-14-2012, 08:29 AM
Will George's Avatar
Car Info: 2006 WRX
Car wont start help
I drove home last night everything was normal, go to drive to school and nothing... Literally nothing. I put my key in the on position, when the electronics all kick on, nothing. Obviously the car won't start. Anyone ever had anything like this?
Car has 85k miles on it. Any info helps thanks in advance
Will George is offline
Old 12-14-2012, 09:16 AM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
Battery, battery leads, ignition.
I have not had that problem but those are three areas to start with.
I hope it is as simple as your battery lead worked its way loose. Check at the battery positive. If that lead is good check at the starter, then at the ground points on the vehicle and battery for the negatative lead.
Shayhan27 is offline
Old 12-14-2012, 09:27 AM
02RS25's Avatar
especially with rainy season now here. a good time for grounds, connections, etc to go bad. id check for corrosion and such, then take out the trusty DVOM
02RS25 is offline
Old 12-14-2012, 04:09 PM
Car Info: 2006 WRX
Thanks guys much appreciated
Old 12-15-2012, 01:03 PM
Car Info: 2006 WRX
The battery lead got loose! Put her back in and it starts right up again. Thanks again, id be screwed without this forum
Old 12-15-2012, 07:56 PM
Shayhan27's Avatar
Sweet my novice interweb diagnostic skills finally worked.....Glad to have been of service...
muskatomas101
12-02-2007 04:30 PM
jeanna0221
05-01-2006 06:58 AM
krillz
07-02-2003 04:37 AM
DDImpreza
05-28-2003 03:10 PM
KnightRider
12-31-2002 04:24 PM
Quick Reply: Car wont start help
