Car wont start help
Old Dec 14, 2012 | 08:29 AM
Will George's Avatar
Car Info: 2006 WRX
Car wont start help
I drove home last night everything was normal, go to drive to school and nothing... Literally nothing. I put my key in the on position, when the electronics all kick on, nothing. Obviously the car won't start. Anyone ever had anything like this?
Car has 85k miles on it. Any info helps thanks in advance
Old Dec 14, 2012 | 09:16 AM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
Battery, battery leads, ignition.
I have not had that problem but those are three areas to start with.
I hope it is as simple as your battery lead worked its way loose. Check at the battery positive. If that lead is good check at the starter, then at the ground points on the vehicle and battery for the negatative lead.
Old Dec 14, 2012 | 09:27 AM
02RS25's Avatar
especially with rainy season now here. a good time for grounds, connections, etc to go bad. id check for corrosion and such, then take out the trusty DVOM
Old Dec 14, 2012 | 04:09 PM
Car Info: 2006 WRX
Thanks guys much appreciated
Old Dec 15, 2012 | 01:03 PM
Car Info: 2006 WRX
The battery lead got loose! Put her back in and it starts right up again. Thanks again, id be screwed without this forum
Old Dec 15, 2012 | 07:56 PM
Shayhan27's Avatar
Sweet my novice interweb diagnostic skills finally worked.....Glad to have been of service...
muskatomas101
Dec 2, 2007 04:30 PM
jeanna0221
May 1, 2006 06:58 AM
krillz
Jul 2, 2003 04:37 AM
DDImpreza
May 28, 2003 03:10 PM
KnightRider
Dec 31, 2002 04:24 PM
