Boost creep on '05 STi
Old Jul 21, 2004 | 02:32 PM
sfwrx2's Avatar
Car Info: 04 aspen white sti
good Question!
Old Jul 23, 2004 | 05:19 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
I have an 05 STi, and I have not noticed a creep...yet.
Old Jul 24, 2004 | 10:19 PM
Krinkov's Avatar
no, still using exact same VF39 with the same P17 exhasut housing. Keep in mind that boost creep only happens when you add an exhasut, so this is an issue that Subaru has no interest in addressing for us.
Old Aug 1, 2004 | 12:22 PM
EnjoyTheView's Avatar
Sorry for the newbie question, but what is boost creep?
Old Aug 1, 2004 | 03:10 PM
RoadSpike's Avatar
Basically means that the turbo keeps putting pressure into the system even though the wastegate is open.
The wastegate is a sort of turbo bypass for exhaust that is supposed to prevent the turbo from cuasing excessive boost pressure.
The reason its bad is the turbo puts unwanted pressure on the system causing dangerous spikes.
There is a long thread on this issue in the "Threads of note" sticky
Old Aug 1, 2004 | 03:44 PM
RoadSpike's Avatar
Originally Posted by JXN
What's the difference between boost creep and boost lag?
I guess thats the same as turbo lag which is the time it takes to spool up the turbo as produce boost in the car.
Sti"izzle"
May 25, 2005 09:03 AM
xicema17x
Oct 7, 2004 10:05 PM
03WRX!!!
Jul 19, 2004 02:40 PM
fish4poi
Oct 27, 2003 09:55 AM
stryfewrx
May 27, 2003 07:30 PM
