Boost?
Old Oct 13, 2004 | 10:06 PM
revvv_pshhh's Avatar
i believe stock is 14.5 and you can boost up to 16.5 anything else the turbo looses breath and won't make boost all the way to redline. I think this is correct. Im a nissan person.
Old Oct 14, 2004 | 12:44 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Without any other mods, I would stick with stock boost levels but make them not drop with an aftermarket EBC.
Old Oct 18, 2004 | 10:58 AM
Wingless Wonder's Avatar
Origami posted by ERIKNLARON
hey if i get a stock sti do the normal break in period then buy a boost controler, can i turn the boost up?
The reason why you have to use caution when playing around with boost controllers on Subaru turbo cars is because the fueling won't be increased properly to match higher boost. While small changes might be okay (and I'm talking less than a pound of boost) anything more may run the engine lean with disastrous results. Without an aftermarket exhaust gas temperature (EGT) gauge properly installed, you'd wouldn't be aware of the lean condition until it was too late.
Engine management such as a reflash or piggyback will take care of both additional boost, fueling, and ignition map changes for more power.
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
