APS tbe
Old Jun 14, 2006 | 12:32 AM
apexwagon's Avatar
Car Info: Sti hatch
APS tbe
the APS tbe on STi's shoots crazy flames with a bov. me n my friend w/ an 06 sti got about a 6' flame out of it. APS=$$$$=performance=awesome. he also got a 13.2 in the 1/4 mile all stock w/ tbe n bov on an uphill track w/ headwinds at like 10mph. pretty cool.
Old Jun 14, 2006 | 12:35 AM
pj21086's Avatar
which bov?
Old Jun 14, 2006 | 07:47 AM
meilers's Avatar
APS != $$$$. I got my 3" TBE for $997.00, one of the least expensive full SS TBEs on the market. Everything APS makes is mid- to low-priced, even the more exotic pieces like tumbler delete valves. The only thing they make that seems overpriced is their TMIC ($800.00). Oh, and full-atmospheric BOVs will eventually cost your friend that motor. Enjoy it while it lasts!
Old Jun 16, 2006 | 01:58 AM
slouie's Avatar
Cool
But if he has the APS bov, he should be safe. The APS bov is not 100% atmospheric. The primary vent is recirculated, and the smaller secondary vent (which only operates under high boost) is atmospheric. I haven't heard about anyone having a problem with this bov yet.
Old Jun 16, 2006 | 02:06 AM
turbo_4_life's Avatar
Car Info: 04 wrx
is this true? anyone
Old Jun 16, 2006 | 07:42 AM
meilers's Avatar
http://www.airpowersystems.com.au/wrx/blow.htm
Dual-stage BOVs are indeed safer than atmospheric, but won't produce the sound people want (this one won't "phhsssttt" at all on a stock motor running stock boost; you have to be running quite a bit more boost than stock to get it to go off).
Old Jun 16, 2006 | 10:36 AM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
I got my APS top mount for $695 brand new . You can adjust the APS bov too.
Old Aug 12, 2006 | 12:03 PM
thesnowboarder's Avatar
Car Info: 1990 turbo miata
Originally Posted by pj21086
which bov?
hks ssq
Old Aug 12, 2006 | 12:04 PM
Really? is this just because it doesnt re-circulate the air.... since you have to put the plug thing it... i never knew it could cost you and engine
Old Aug 12, 2006 | 03:17 PM
meilers's Avatar
Well, I'm exaggerating slightly. A full-atmospheric BOV can cause your engine to run excessively rich, because you are letting out air that has already been compensated for in the A/F mixture by the ECU according to its measurements at the MAF. If you've got a host of other badly-planned mods (say, a manual boost controller turned up too high, the 3/16th mod, a CAI) all of those together can cause enough knock and other trouble to burn a valve or a piston ring. The reason I'm wary about this is that for some reason, people with the full-atmospheric BOV are also likely to have the other cheapo, dangerous mods as well, because those mods are really common in the Civic/Acura modding scene.
woocabin
May 3, 2010 08:34 PM
RallySportDirect
Engine and Drivetrain
13
Dec 12, 2008 12:25 PM
no593
Jan 22, 2008 09:01 AM
Blu05Sti
Dec 5, 2005 01:11 PM
STi_Mark
May 11, 2005 09:02 AM
