AP V2 Stage 2 Map Compared to Stock STi Maps
Old Aug 3, 2007 | 07:47 PM
A170123W's Avatar
Car Info: 2007 Subaru Impreza WRX STi
So I have a 07 STi and I just installed my Turbo Back System (COBB 3" Catback and 3" Invidia V2 Catless Downpipe. I went for a small spin with some friends right after installing just my turboback and my friends said it PULLED pretty hard. Then I installed the COBB AP v2 with the stock 91 Octane map and they said it doesn't seem like it pulls as hard. Has anyone ran into this kind of issue? I was thinking if I should go back to my stock map and have my check engine light running untill I decide to get a protune.
Another question is if I decide to go back to my stock map the the AP downloaded from my car, how would I do that? Would I go uninstall the AP or would I have to choose the stock map it downloaded?
Thank You!
Old Aug 9, 2007 | 10:30 AM
slodsm's Avatar
Car Info: 2006 WRX limited, Aspen White, still stock at the
Boost creep from no EM probably caused it to pull a lot harder before.
Old Aug 9, 2007 | 11:39 PM
03_Impreza_Al's Avatar
Run the AP stage 2 it's safer...
I'd get a protune if you are planning to upgrade your turbo and other goodies.
If you are just planning to stick with a stage 2 map I'd go with an Opensource stage 2 map. Then sell the Cobb AP.
hp
Dec 3, 2007 10:33 PM
lburrrna
Jun 28, 2006 05:26 PM
carletto
Jul 23, 2005 03:20 PM
