16 psi
Old Aug 10, 2006 | 11:16 PM
VRT Gump's Avatar
16 psi
I just put on a Defi boost guage and got up to 16 psi on a stock 2006 wrx turbo. I am running a Helix turbo-back and stage 2 on the AP. Is that to much boost for that turbo?
Old Aug 11, 2006 | 01:49 AM
testes1010's Avatar
no, not too much.....more important what does the AP live reading show for boost pressure? that is what the actual boost is, not what the gauge reads.
Old Aug 11, 2006 | 07:31 AM
VRT Gump's Avatar
I havent used that yet. I put up 17psi on the guage this morning in 5th.
Old Aug 12, 2006 | 01:22 AM
thesenior's Avatar
Car Info: '11 STi 4dr
id be more worried about how the injectors are holding up and what duty cycle they are at when pushing enough fuel to feed twice as much as stock boost
Old Aug 12, 2006 | 01:57 AM
WRX409's Avatar
Car Info: 04 WRX
That isn't too much but, that is good boost psi. on the
stock turbo with your mods.That boost gauge is probably
dead on accurate.
Old Aug 12, 2006 | 02:11 AM
RedStage's Avatar
Car Info: Ver IV STi Wagon
Who did what????
Old Sep 4, 2006 | 11:28 PM
DTO808's Avatar
Car Info: 06 WRX TR
17psi sounds like a lot whats the stock psi anyway??
Old Sep 4, 2006 | 11:45 PM
Jakes02's Avatar
Car Info: 2002 WRX
13.5 psi
Old Sep 4, 2006 | 11:47 PM
Jakes02's Avatar
Car Info: 2002 WRX
When you are WOT do you have consistent 16 psi or does it fluctuate?
Old Sep 6, 2006 | 06:23 PM
ScobyWRX's Avatar
Car Info: 07 Ducati monster S2R1K
read the map notes on cobbs page " target peak boost pressure is 15.2+- .07"
and like Testes1010 stated check what the AP live boost reading is then you will know.
as for dutie cycle 06 injectors can handel it, but it's the pump you have to worry about
Old Sep 13, 2006 | 11:09 AM
RockStar541's Avatar
Car Info: 2006 Subaru Impreza WRX TR
Originally Posted by Jakes02
13.5 psi
On 2006 WRX Models, boost is 11.6psi stock. It was 13.5 previously on WRX models, but in 06 they started using a smaller turbo to decrease turbo lag.
Old Sep 13, 2006 | 11:52 AM
VRT Gump's Avatar
The guage peak is between 17 and 17.5psi and the Cobb AP is from 15.7 to 16.2psi.
I also have a K&N intake and an STi TMIC so that may be why the boost is a little higher.
also, for the record, RedStage did about 90% of the work installing my guage.
Old Sep 13, 2006 | 11:53 AM
VRT Gump's Avatar
WOT its pretty much staying between 16-17 depending on what gear I am in. that is on the guage, not the AP.
Old Sep 14, 2006 | 12:56 PM
jeffsndyer's Avatar
Car Info: '04 FXT
lol smaller turbo.... its the same turbo from 02-06 for the wrx... lol u better search more
Old Sep 15, 2006 | 03:21 PM
ScobyWRX's Avatar
The turbo is the same the reason we boost less is due to the raise in compression ratio 2.5 runs 8:5.1 2.0 runs 8:0.1 I believe this was done to prevent knock and to get better torque
