02 wrx oil leak
Car Info: 02 wrx sport wagon
02 wrx oil leak
I was on the freeway in 5th gear. I go to pass a semi (not going more than 70) then i hear a pop. i notice no power loss or boost leak. i pulled over and noticed oil leaking and smoking from engine. I immediately killed the engine and towed it to my house. after getting it home I inspected under the car. Oil everywhere it seemed like. But alot leaking around the turbo. I used degreaser and cleaned it best i could. I filled up with more oil (about 2 1/4 quarts). I started the motor and saw no leaks. Let motor idle for about 10-15 min. no leak. Took it down the street no leak no smoke. Boosted it a little.....boom smoke and leaking like a stuck pig. I assume its the oil return line but im not ase certified and would like your opinion. So if you have read this far thanks and id appreciate your input.
Suby B
Suby B
salvator_rizzo
Jul 10, 2009 04:10 PM
yzercyber
Mar 2, 2008 06:02 PM
bigdaddy
Jul 10, 2003 12:09 PM
Zoeb2s
Dec 30, 2002 10:43 AM
