[h] noise under boost - like supercharger
Old Feb 22, 2009 | 06:28 PM
jinorazi's Avatar
Car Info: 05 cgm imp
so yesterday, in the rain, as i stepped on the gas i noticed a noise i've never heard before. i searched in the forums but no answer.
it happens under full boost, instead of hearing my turbo spool through the intake, i hear another noise, like a supercharger whine. scoo_b heard it in my car, he wasnt sure what it is.
i got k&n sri, tbe w/ silencer put on.
maybe a leak on the dp/turbo, the nuts tend to get loose there, i will look in to the when its not raining.
help will be appreciated, thanks.
Old Feb 22, 2009 | 06:32 PM
wrxisthebest's Avatar
power steering pump?
Old Feb 22, 2009 | 07:40 PM
pwnx0rz's Avatar
Car Info: '02 WRX wagon
dude i have the same problem. its really ****in annoying and iono how to fix it. is there a place i can get it checked out?
Old Feb 23, 2009 | 12:05 AM
Jin's Avatar
Jin
Car Info: 05 CGM STi to be converted to RS
would that vary with boost?
the sound will gain volumn just like turbo spooling.
Old Feb 23, 2009 | 12:34 AM
you did not state in the OP that it varies the boost.
the reason you would hear it under full boost is cause you motor is under load. belts become under load at the simultaneously. cause your PS to make the "Supercharger Whine"
Old Feb 23, 2009 | 10:37 AM
Jin's Avatar
Jin
is this urgent or can i wait until action needs to be taken.
Old Feb 26, 2009 | 08:16 PM
blaccrex's Avatar
Car Info: 2007 impreza wrx
its most likely an exhaust leak from your dp gasket. i had that same noise, sounds like a cat almost...my gasket was broken so it was very loud. u did mention loose bolts.
Old Mar 2, 2009 | 05:23 PM
Jin's Avatar
Jin
check the bolts on the dp/turbo and they're on there.
my o2 bung tends to get loose because crucial didnt send me the right one, tightened.
so the sound is still there, happens near 5k rpm, does not vary with rpm but with boost.
Old Mar 23, 2009 | 10:15 PM
DemonPossessed's Avatar
Car Info: 05 wrx
i dont think it is a post turbo (downpipe leak)
more likely an intercooler leak? intercooler hose? or ypipe connection to intercooler
WRXncrew
14
May 7, 2014 12:41 PM
downsti
Jul 9, 2009 11:40 AM
WrbImprezaSti
15
Dec 1, 2008 06:05 PM
PURIST
Dec 20, 2007 11:21 PM
