wierd whistling noise under boost
Old Jul 17, 2008 | 02:31 AM
WrbImprezaSti's Avatar
Car Info: WRX
cars making this loud high pitched whistling noise under boost, not there until the turbo starts building boost. Does anyone know wtf is going on?
2005 Sti mods are:
-AEM CAI
-Helix Up
-Invidia DP
-Perrin EL Manifold
-Srs catback
Old Jul 17, 2008 | 02:39 AM
Choku Dori's Avatar
Car Info: Corvette Z51
It's your turbo spooling.
Good one.
Old Jul 17, 2008 | 02:46 AM
Car Info: WRX
Good one.
i can hear the whistle sound over the turbo spooling......... really annoying high pitched whistle, has to be related to boost because the more boost you build the loud it gets.
Old Jul 17, 2008 | 02:49 AM
East Bay STI's Avatar
Car Info: 2000 Tacoma Pre-Runner 4 Cyl.
Welcome tot he up pipe exhaust leak. Mine leaks, we used the AP Street Tuner software to see if I was hitting target boost and I was so I don't care. Only happens to whistle under boost, either it will close after enough carbon build up happens or you could double gasket the header to up pipe section or try other gaskets until it goes away. GL
-Gio
Old Jul 17, 2008 | 03:04 AM
Dnayukns's Avatar
Car Info: 07 Wrx
Yup, mine does that all day too. Lols. You lose some boost sometimes - sometimes you dunt. Getta uppipe with a flex joint. Thats what Speedelement told me when i went there haha.
Old Jul 17, 2008 | 03:21 AM
Car Info: WRX
thanks guys, its holding boost just fine, so i'll just let it be.
Old Jul 17, 2008 | 04:34 AM
pwnx0rz's Avatar
Car Info: '02 WRX wagon
maybe i have the same thing, except mine starts whistling since start up. any one know whats wrong?
Old Jul 17, 2008 | 09:30 AM
chubs22's Avatar
Car Info: '04 STi
Yup sounds like an exhaust leak. I think it is due to the 2 bolt after market up pipes. I use to get it until the piping heated up. After I switched to a 3 bolt design (which included headers) the noise never came back.
Old Jul 17, 2008 | 10:06 AM
wm07's Avatar
Car Info: 04 STi & an autox Lemming
Use some better gaskets. I fixed mine using a copper gasket set.
Old Jul 17, 2008 | 10:11 AM
Onizuka's Avatar
Car Info: 04 STi
One time I had a leak from my BPV to my TMIC and it made this super duper loud high pitched wine - so you might want to check the bolts on your BPV and TMIC.
Old Jul 17, 2008 | 10:27 AM
subie OCD's Avatar
Car Info: 04 STi
Also check the intercooler hoses.
Old Aug 21, 2008 | 02:29 PM
papakiet's Avatar
Car Info: Smokin' Joe
mine does it too..but goes away after the car warms up a bit..
Old Aug 29, 2008 | 05:18 PM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
maybe it would be better if you put your stock intake box on.
Old Nov 29, 2008 | 01:57 AM
imHELLAslow's Avatar
Car Info: 20psi Daily!
hai, i had the same problem couple days ago, sounded like a supercharger going with the boost, not rpms. it could mean leaky uppipe or boost leak after the turbo if it sounds like this http://www.youtube.com/watch?v=wS-x472vFJs
i thought it wasnt untill i tightened everything [even though everything LOOKED tight] the sound went away due the a leak at the intercooler hose. i thought it was the rip in the turbo inlet pipe but it wasnt, but it gave me a reason to upgrade the turbo inlet anyways. good luck.
Old Nov 29, 2008 | 07:49 AM
VRT MBasile's Avatar
yeah, I got that once when I had to use a friends BOV so he could use my BPV for the state ref. It was the most annoying thing ever.
