WRX's Autometer Boost Gauge is Inaccurate?????
Old May 5, 2004 | 07:34 AM
GR8-WRX's Avatar
Car Info: 2010 370z Roadster, 2008 Frontier CrewCab
Does he have the 3/16" mod? I believe some folks have experienced weird spiking like you have described after the 3/16" mod.
Old May 5, 2004 | 03:35 PM
international B's Avatar
Chewwwwy
i had a auto meter boost gauge for a while... it sucked, with no mods it would read inconsistantly, even at atmospheric pressure, it would read from 3psi to -4 psi... i would reccomend a different gauge. if your car is having real boost problems, there would be a cel. also check the stiff plastic hose for the autometer, it can easily get crimped and cause problems.
Old May 6, 2004 | 05:49 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
I seriously doubt this has anything to do with the three sixteenths mod. It's more than likely either a crimp in the poor quality nylon vacuum line that AutoMeter supplies with the gauge or the low quality compression fittings they supply. I would recommend using better vacuum line and safety wire or hose clamps with proper barb fittings to secure the connections. It's not always easy to find the hardware, but it's worth it in the long run to do it right and know that you're getting good readings.
Although the quality of the fittings and line AutoMeter sends out is poor, the quality of the gauge I have found to be quite good. When connected to the proper source, with the proper fittings and hardware (just like any non-electronic gauge) it gives me a rock solid needle and accurate readings. You don't have to spend $200+ to get a boost gauge that works, you just have to spend some time installing it properly.
Tim
www.stoptech.com
gesundlich
Dec 27, 2005 05:05 PM
Shaitiger
Mar 28, 2004 02:20 PM
TastyTurbo
Dec 2, 2003 08:27 AM
IS300
Nov 18, 2003 05:25 PM
