WRX turbo...
Old May 12, 2005 | 07:18 PM
SubyWRXdude's Avatar
Are you sure your turbo is not kicking in at all? Do you hear it spool, turn off the radio drive and u should be able to hear it spool after about 2.7k. If you dont than your turbo is not spooling. Check to see if it's spooling than the problem can be narrow down. You might also want to try resetting your ecu if that helps.
JDMGC8
May 29, 2009 08:07 PM
WrsExX
Mar 30, 2005 06:54 PM
hoopty
Jan 16, 2005 10:32 PM
stg2lgcy00
Dec 2, 2004 09:19 AM
singsing
May 24, 2003 03:19 AM
