WRX TMIC to STi TMIC
Old Jan 5, 2007 | 12:14 PM
1neWRX's Avatar
Car Info: White 04 WRX
I will be taking out my WRX TMIC and replacing it with the STi TMIC to go along with my other mods currently on the car. my question is once the STi tmic is installed is it necessary to run STi splitter and shroud? basically will tehre be enough air flow with the wrx ones, or might it get too hot under there? Thanks in advance
Old Jan 5, 2007 | 04:23 PM
RedStage's Avatar
Car Info: Ver IV STi Wagon
It's "Better" if you have the splitter and shroud. How much is subjective.
You might need to get different hoses from the Turbo to intercooler and Intercooler to intake manifold.
There are some decent threads on NASIOC about this. Would definately look into it before you pull off the WRX TMIC.
Look through this thread:
http://forums.nasioc.com/forums/showthread.php?t=952204
I followed the recommended advice on the Hose Techniques Hoses and had no problems.
Old Jan 6, 2007 | 03:01 AM
1neWRX's Avatar
yea i have a y-pipe that came with the TMIC. i was hoping it was the STi ypipe, but i got a helix ypipe...hopefully it fits well.
btw thanks for link, reading up on it right now
Old Jan 6, 2007 | 09:46 AM
STI RUSH's Avatar
Car Info: 13 FR-S/05 STI
HELIX y pipe and STi TMIC will fit fine. . .
Old Jan 8, 2007 | 09:30 PM
1neWRX's Avatar
also am i able to use OEM STi air splitter with OEM WRX hood scoop?
Old Jan 20, 2007 | 10:13 PM
InvertedB's Avatar
Car Info: '02 MBP WRX Sedan
No, it will be too tall. You need a STi hood scoop to use the STi splitter.
Old Feb 2, 2007 | 10:57 PM
1neWRX's Avatar
then would using my stock splitter and scoop have enough air flow for a sti tmic
Old Feb 2, 2007 | 11:55 PM
WRX409's Avatar
Car Info: 04 WRX
If you are installing a STI TMIC than
I would also go with a STI hood scoop because it is slightly taller
and will let more air in and make the STI TMIC more effective.
Old Feb 6, 2007 | 07:39 PM
AzN121184's Avatar
Car Info: civic
did u get this installed yet?
Old Feb 9, 2007 | 12:20 AM
1neWRX's Avatar
just got it installed and tuned today at GST.
Old Feb 9, 2007 | 12:26 PM
Jake's Avatar
u put out good numbers...
Old Feb 9, 2007 | 12:29 PM
VRT Gump's Avatar
what year is your WRX?? the 06 hood scoop is the same size as the STI so it would work. According to subaru parts department they wont, even though the dimensions are the same. If anything go with a zero sports spliter.
Old Feb 16, 2007 | 12:36 AM
1neWRX's Avatar
i have an 04. currently looking for STi hoodscoop and splitter. unless splitter will work wiht my wrx hood scoop.
Old Feb 16, 2007 | 12:45 AM
mgb04's Avatar
Car Info: 04 STI, 03 M3, 08 335i, 15 i3
splitter will be too tall for the wrx hood scoop. you'll need the sti scoop.
Old Feb 16, 2007 | 01:08 AM
1neWRX's Avatar
i like my mini scoop heh..so what splitters would work with wrx scoop and will still be effective?
