WRX runnin rough, rich, and smokin!!! HELP
What does the smoke that is coming from around the turbo smell like? If it is oil, you will be able to tell. The only other thing that goes to the turbo is the coolant... You may want to check that too, since you will be down there anyway.
smoke smells like gas and oil, turbo checked out good so far, only minimal oil on the i/c side. BUT.......when i took of the i/c i noticed my BOV was missing to setting screws and was quite loose which could possibly be a large part of my problem. Im sure it is leaking air. Im gonna reset that with new screws and some thread lock tomorrow and see what happens.
Go in and have a Subaru dealer check your ignition coils. Utecs have a habit of burning out coils, which causes them to randomly misfire. Obviously this won't be covered under warranty with your mods, but it shouldn't take long to test for one specific problem rather than a general diagnosis. Translation- it should be cheap, like less than an hours' labor.
Mosh
Jan 8, 2004 04:37 PM
mario
Sep 24, 2003 06:32 PM
Pi7467mp
Mar 31, 2003 03:56 PM
