WRX runnin rough, rich, and smokin!!! HELP
Old Sep 26, 2003 | 04:11 PM
tim's Avatar
tim
First of all, if your EGT's are really hot, you are NOT runing too rich.
Old Sep 27, 2003 | 09:45 AM
awns729's Avatar
Car Info: want a WRX
machaf may be right...what mods? could it be something with the spark plugs? im assuming you checked all wires?
Old Sep 27, 2003 | 12:52 PM
Uncle Scotty's Avatar
airbornewilly...check your PM's
Old Sep 27, 2003 | 08:05 PM
tim's Avatar
tim
I agree with machaf--sonds like a fuel problem. I think it is something controlling your fuel... something like injectors or the pressure regulator. If the regulator broke and got stuck open, it could be flooding the injectors(?).
Old Sep 28, 2003 | 01:16 AM
tim's Avatar
tim
maybe.... Im not exactly sure, but it makes sense that if the car though it was getting too much air, it would compensate by adding a lot of fuel.
Old Sep 28, 2003 | 01:25 AM
tim's Avatar
tim
http://www.sficc.net/features/feature4.html
http://hondata.com/techlambda.html
http://www.datsuns.com/Tech/oxygen_sensors.htm
Old Sep 28, 2003 | 01:42 AM
tim's Avatar
tim
Then again--
I really dont see how the MAF would cause the car to run that rich. Could it be possible that the ECU is screwing up that data that it is receiving and causing (or helping to cause) your problem? you said you put it back to stock mode, but still...
