WRX to GC8 swap, What do I do?
Old Nov 10, 2004 | 04:20 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
Originally Posted by Polishguy701
Whats goin on guys. I got a 99 impreza RS. I want to do a 2002 WRX swap. I found a motor but the guy said that the front driverside cylinder has very little compression. He then said he took it to the dealer and the dealer said that the cylider was dead. Is this a big problem to fix. I can get the motor for about a grand from the guy complete with the ECU, engine harness, alternator, intercooler, manifolds, up pipe, down pipe and stock turbo. Is the motor worth buying? Also what would i need for the swap. I heard that my 2.5 RS trans is better to use also i would just need a new clutch. I was also told the only thing i would need for the swap would be the complete motor, bigger exhaust, new clutch for the 2.5 rs trans and a jdm sti crossmember. Did I miss anything guys. Your help and advice would be greatly appreciated?
switch your title. GC8 to WRX swap
Old Nov 10, 2004 | 05:15 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
I wouldn't buy an engine with a dead cylinder.
Old Nov 11, 2004 | 10:26 AM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
I have to concur
Old Nov 16, 2004 | 01:14 PM
EndlessWaltz RS's Avatar
Car Info: 00 BRP RS LIC'd 01 EJ207 + non DCCD 6 Speed
www.LICMotorsports.com
PacificLegacy
Aug 26, 2014 09:54 PM
ch0g
Aug 27, 2006 06:14 PM
Polishguy701
Nov 6, 2003 11:54 PM
tsuanosuke
Jun 1, 2003 04:15 PM
andybpopma
39
Apr 26, 2003 04:58 AM
