WRX '02 Cylinder Heads cracked - any suggestions?
Old Apr 16, 2009 | 06:51 PM
CompuPsych's Avatar
Car Info: Subaru WRX 2002
I had my 2002 WRX (109,000 miles) in the shop to have a head gasket replacement and was told that there are cracks in both cylinder heads. There doesn't appear to be any coolant leaking at this point. The options I've been given:
1. Replaced both with Subaru heads ($1000 each plus labor).
2. Replace the entire engine.
3. Use the existing heads and pray.
I've done some research and have found places that will refurbish heads, but I haven't found any info about the reliability of the companies.
Any suggestions of other options or solid companies that reburbish head or provide new heads at a reasonable cost?
Any help would be greatly appreciated!
Thanks,
Jon
Old Apr 16, 2009 | 06:59 PM
RLLYRCR's Avatar
Car Info: 1988 Yoda
You could go to atarco or similar places and get a full motor for like 1500. You should be able to find used wrx heads for under a grand easily.
Old Apr 17, 2009 | 12:24 AM
WRX409's Avatar
Car Info: 04 WRX
If that is your predicament I would definitely go the
#1 route and replace your cylinder heads with new Subaru units.
Damage done to the cylinder heads is one of the costly
consequences of having a headgasket fail.
I hope you are able to get your vehicle fixed soon.
jonpark
Subaru OEM Parts For Sale
May 7, 2008 07:47 PM
EJ20Legacy
Nov 13, 2006 05:47 PM
wombatsauce
Apr 14, 2005 10:30 AM
Quick Time
Wanted
May 27, 2003 09:10 AM
