wot at 3500rpm cuts in and out?
Old Feb 27, 2006 | 04:05 PM
cjmxcel's Avatar
Car Info: 02 wrx
i have a 02 wrx that i picked up a month ago and now it cuts in and out at about 3500rpm wot. i have up/dp that is it for modes. any ideas?
Old Feb 27, 2006 | 04:24 PM
like complete shut down or hesitation?
Old Feb 27, 2006 | 06:10 PM
cjmxcel's Avatar
Car Info: 02 wrx
Both
Both when the gas gage gets to ½ and under hard cornering it cuts out and when at wot at any tank fullness it dose have hesitation.
Old Feb 28, 2006 | 10:12 AM
cjmxcel's Avatar
Car Info: 02 wrx
bump
Old Mar 1, 2006 | 09:40 AM
Keisatsu's Avatar
Car Info: Broken ass stock '02 WRX
Are you sayin it cuts out completely like when you are super low on gas?
my boost has always fluctuated (doesn't "cut out" though) when say going from 25-50 up a hill, nothing terrible, almost like when you are rolling through a parking lot in first gear and you touch the throttle and the drivetrain bounces a little (though not as much). My friends WRX's do the same thing '02's and 03's, so I always thought it was normal.
Old Mar 3, 2006 | 09:27 PM
myweaponwrx's Avatar
Troll
Car Info: 03 BLACK WRX & 05 EVO
take it to the Subaru dealer
Old Mar 5, 2006 | 10:34 AM
cjmxcel's Avatar
Car Info: 02 wrx
any other suggestions
Old Mar 6, 2006 | 07:54 PM
jlam86's Avatar
did it have an accessport on it?
There is a setting called "valet" and it cuts the fuel off at 3500rpm. just so when u take your car for repairs, they won't rape it.
If it is the case and it's running on realtime, just disconnect the battery. and reattach it. you will then be back to the regular basemap
ALL THIS IS ONLY IF THERE WAS ACCESSPORT AND SET ON THIS MODE! hope that helps! goodluck
Old Mar 7, 2006 | 03:26 PM
cjmxcel's Avatar
Car Info: 02 wrx
no it dose not
Old Mar 8, 2006 | 02:09 AM
cjmxcel's Avatar
Car Info: 02 wrx
bump
Old Mar 19, 2006 | 05:18 PM
BlueREX04's Avatar
Car Info: 04 WRX WR Blue
I had this same problem with my 04 WRX took it to the dealer in Wisconsin (dont ever go) they said that the turbo is shot.... I had a different explination from NASIOC. I was getting a rattling from the turbo side a rattle about 5k and no grunt at 5,100 and a cel that matched bank one sensor one... forgot what the actual cel code was but one guy said that it was the up pipe... so I bought a new/used one and put that in today, as a matter of fact, and no more rattle at 4k and runs boost all the way to 7k. but getting 7.x psi ... not sure what that is about. still trying to figure that one out as we speak :-) hope this helps some.
slow04wrx
Mar 20, 2013 10:17 PM
scrager
Feb 22, 2004 07:16 AM
daybreak
Mar 29, 2003 07:09 PM
EtchyLives
Mar 21, 2003 07:25 PM
DetailAddict
Jan 17, 2003 06:36 AM
