wondering about wastegate fix
Old Jun 27, 2007 | 07:09 AM
caseysrex's Avatar
Car Info: 03' WRX
I just did the wastegate flutter fix and i turned the wastegate arm 2 turns to the right. it really didnt seem to do anything. i am not even sure if i did it right. once i popped off the c-clip i popped the arm up and then i turned the whole arm to the right and all the way around two turns. is that right or did i do nothing in the process? should i do another turn or am i even doing it right? Am i really even going to notice a difference? thanks for all your help in advance!
Old Jun 29, 2007 | 11:17 AM
caseysrex's Avatar
Car Info: 03' WRX
any advice at all would help!
Old Jun 30, 2007 | 07:48 PM
flatline's Avatar
Car Info: Cage and Slicks and Wing OH MY!!
sounds like you did it exactly right,
I guess the first question that should be posed is. WHY DID YOU DO IT??
Alot of people do it expecting great things
Old Jun 30, 2007 | 09:30 PM
testes1010's Avatar
no, you did it wrong(if I'm reading your post correctly)
you do NOT move the arm, only the part on the end.
1, with the e-clip on loosen the nut(2 full turns) on in the arm near the end.
2, remove e-clip(do not drop & lose)
3, pull arm off of wastegate pivot arm, screw in endpiece 2 turns
4, put arm back on wastegate pivot arm
5, put on e-clip
6, tighten nut back down
Old Jul 4, 2007 | 02:01 PM
caseysrex's Avatar
Car Info: 03' WRX
oh my ok i feel stupid! that would be the more logical approach! hey thanks so much! welp now its time to undo what i did and do it the right way! and to answer the previous question i did it because i have a lot of flutter spooling up in low boost situations. but seriously that helps so much! thanks man!
Old Jul 5, 2007 | 01:17 PM
caseysrex's Avatar
Car Info: 03' WRX
ok so i fixed my problem! thank you testes1010! i was barely hitting 14 psi before adjusting the arm, then i did two turns and now i am hitting around 15.2 psi! which is awesome cause i am at about 6,000 ft altitude! it really did help a ton. my car hasnt actually pushed me in my seat yet until today! it runs awesome! anyone not hitting boost target i would definitely recommend it! awesome quick fix! also the flutter is pretty much gone!
Old Jul 6, 2007 | 12:23 AM
thehunv6's Avatar
Car Info: '02 PDXTuned Wagon
Are you getting 15.2psi in all gears?
Old Jul 6, 2007 | 06:48 AM
caseysrex's Avatar
Car Info: 03' WRX
no only in fourth. and a little lower in 1st 2nd and 3rd. i couldnt do a 5th gear pull though
nallen316s
Oct 6, 2014 11:54 AM
hey1230000
May 19, 2010 07:27 PM
scby blu
Jan 14, 2008 09:37 PM
xs_wrx
Feb 27, 2006 06:27 PM
EQ Tuning
Nov 5, 2004 12:07 AM
