Will OEM STi top-mount be sufficient for 16g turbo? (was: Intercooler question...?)
Old Oct 14, 2006 | 02:53 PM
meilers's Avatar
Out of curiosity, has anyone actually weighed these intercoolers? I'd love to see the actual mass of the eBay cheapies vs. STI stock vs. some of the pricey name-brand models (Perrin, APS, AVO, Blitz). Ideally you want the lightest intercooler with the largest surface area; less metal to soak up heat and store it, and more area to cool when air blows across it. This is assuming that the intercooler isn't too restrictive to airflow to negate the gains!
I was certainly surprised at how light the stock WRX intercooler is, and the APS I upgraded to was just a bit heavier. The end tanks of some of the eBay knockoffs look extremely large and heavily welded, but they may save weight in the core.
Has anyone ever made a copper intercooler? Ounce for ounce, copper is many times more efficient than aluminum at transferring heat... It would be pretty fragile, but you could just use copper for the core and aluminim for the outside casing.
Old Oct 15, 2006 | 04:15 PM
Krinkov's Avatar
Originally Posted by subie OCD
Yes, I dont see why anyone would buy a used STi intercooler when you can get an ebay one for much cheaper! I mean people sell them for like $300. IMO that is a rip-off.
hmm, think you mistook my point, I was actually saying the stock stamped STI top-mounts have less thermal conductive mass so would resist heat soak much better than the heavier cast tank top-mounts. Driving for a couple minutes cool the cores but the end tanks are still hot as hell, either way any top mount air-to-air is going to be compromised, its only a matter of whats the right size for amount of cooling versus its amount of heat soak, without actually testing each one in differnt conditions with a air intake sensor we can only speculate. Thats why the best thing to do with a TMIC is convert it to an air-to-water intercooler, and that exactly why you want the stock STI TMIC
as you can see in this pic, a side effct of the stamped construction on the stock TMIC, the core sits about 1/2 deeper than the sides on the top and bottom,
this makes a perfect tub that only needs to be capped off on both sides with a 3/16" thick sheet of aluminum like this.
A Yamaha YZR 600 motorcycle radiatior makes a perfect heat exchanger that fits perfectly right in front of the radiator
these can be bought off Ebay for NOTHING, I got mine for $35, heres one that went with for about $30 they all come with a handy 12v fan to you will use as well
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
nice 1" thick core, should come with a radiator cap too which is handy
this raciator comes with 1" outlets, but you will be using 1/2" hose fittings, so cut these off and plug them
heres the radiator with the 1" outlets cut and plugged and a brass 1/2" 90 degree hose fitting fit into the stock temp sender outlet. the radiator already has a 1/2" hose fitting directly diaganol to this spot from the factory, thanks Yamaha!
for the pump, heres 2 Bosch electric water pumps, both 12v centrifugal constant use units. The middle one is out of a mercedes, the same unit is used on VWs and can be found off Ebay for about $30-40, the one on the right is a Ford Motorsports upgrade one for the Ford Lightning AWIC. These can be bought new off Ebay for $80-90.
Should have the whole thing put together this week, I'll post more pics as the project progresses, you should be able to do this yourself with hand tools and NO welding, and keep it around $150, stay tuned
Old Oct 15, 2006 | 06:15 PM
subie OCD's Avatar
Car Info: 04 STi
Originally Posted by Krinkov
hmm, think you mistook my point, I was actually saying the stock stamped STI top-mounts have less thermal conductive mass so would resist heat soak much better than the heavier cast tank top-mounts. Driving for a couple minutes cool the cores but the end tanks are still hot as hell.
Wouldnt the bigger endtakes soaking up the heat be better than the core taking it?
I dont know, Im just trying to learn more....Ive always read that people got more power with larger topmounts over the STi ones...
Yes the FMIC will be ideal for heatsoak but the installation, bumper modification and cost are a little to much for me. In my experience with the stock turbo, I dont really feel the effect of heatsoak with my big ic...and it can get REALLY hot sitting in stop and go traffic in the summertime.
I do agree that the size of the ic you choose should match your turbo. Hopefully mine will match my 18g well
Nice project you got there, looks awesome!
Old Oct 15, 2006 | 06:43 PM
Krinkov's Avatar
thermal dynamics law dictates that heat will always travel to cold, so how big and efficient the core can cool will be compromised by how much much heat is under the hood and how big your endtanks(heat sinks) are. Like I said, I dont have an exact figure on how hot and for long long the big intercoolers can go before they become interheaters, but you cannot change thermodynamics. Ideally, for a air-to-air TMIC you would want plastic endtanks like the ones on the new WRXs, theres not many better insulators in the world than plastic, but I dont think you would find any companies that would make larger aftermarket ICs with plastic endtanks since people would think they looked cheap, oh well
as for my AWIC, the heat exchanger is slim enough to slip between the front of the radiator and behind the bumper beam, so no cutting of anything
Old Oct 15, 2006 | 09:29 PM
Jakes02's Avatar
Car Info: 2002 WRX
<----R-tard?
Krinkov, what are you doing with the sheet metal? I'd like to give this a shot since I'm cheap and broke. Looking forward to seeing more pics.
Old Oct 16, 2006 | 11:10 PM
Krinkov's Avatar
Originally Posted by Jakes02
<----R-tard?
cap the air-air core off to make it a water-air core
Old Oct 16, 2006 | 11:58 PM
K6DimE's Avatar
Car Info: 01 Impreza WRX
cool beans looking good hope it works so i can try it out
Old Oct 17, 2006 | 12:31 AM
Jakes02's Avatar
Car Info: 2002 WRX
OK, now I'm reeeeeally lost. What part gets filled with water/ where does the line go into the IC?
Old Oct 17, 2006 | 12:35 AM
Krinkov's Avatar
that area that is now sealed off by the aluminum sheets is filled with water, the water outlets are not installed yet
Old Oct 17, 2006 | 12:52 AM
Jakes02's Avatar
Car Info: 2002 WRX
OK, i think I'm starting to get it. So the holes get drilled in the side of the IC? one on each side I assume? How are you getting the sheet metal sealed to the IC?
Old Oct 17, 2006 | 12:54 AM
Krinkov's Avatar
right into the plates, than water gets pumped in, gimme a couple days and you'll see
Old Oct 17, 2006 | 01:40 AM
Jakes02's Avatar
Car Info: 2002 WRX
i look forward to this craziness.
Old Oct 17, 2006 | 11:45 AM
meilers's Avatar
Have any Subaru models come with air/water intercooling? I'm really curious about your results with this; it looks very similar to a watercooling setup for a PC, scaled up.
Get some temp sensors and put one at the entdank on the turbo side, and one on the intake manifold and measure the temp differential!
Old Oct 18, 2006 | 01:18 AM
Krinkov's Avatar
yeah, the old liberty came with one, heres a pic of its IC swaped into an impreza
Im not going to bother doing any very detailed before/after temp difference results, I suppose idealy I would take intake temps at the TB before and after, but since those temps are not static I would have to spend quite a while before the install and afterwards monitoring and recording the temps durring different driving conditions,outside temps, boost levels, etc, to get any meaningful results. And Im just really too busy/lazy to do all that
Im going to keep it a bit more simple, since we already know that XX temp of water through the core is going to carry away more heat from the IC than the same temp of air through the core, all Im going to focus on is monitoring the water temp entering the IC to make sure the the radiator and fan are doing their job, if I can keep that in the range I want I'll know the water is doing its part once it gets in there
Old Oct 18, 2006 | 02:17 AM
Jakes02's Avatar
Car Info: 2002 WRX
are you gonna do a write up on this once you get it done? If not I'll have to bother you with a bunch of questions
