Will catless uppipe pass smog test? (split off from another thread)
Old Aug 2, 2006 | 11:34 PM
WRX409's Avatar
Car Info: 04 WRX
Originally Posted by TheScoobyMedic
just spend $160 on a up pipe and dont bother with guttin it, its easier, plus youll have you stock up pipe intact in case you ever need it again, maybe smog inspection or somethin
to gut means to remove the precat from the up pipe
+1
Don't mean to highjack your thread but, I have a question.
Will you notest any different in turbo spool time replacing the stock uppipe for
a aftermarket catted uppipe? Just wondering? Will you fail a emission test
with your uppipe not being catted?
Old Aug 3, 2006 | 07:51 PM
TurnWRX's Avatar
Originally Posted by WRX409
+1
there are no aftermarket catted uppipes. The whole purpose of buying an aftermarket uppipe is to get rid of the stock cat in the stock uppipe. You should notice your turbo spool roughly 500 rpms earlier if u went with an aftermarket up.
If u live in CA u can pass smog without a cat in the uppipe so long as they don't do a thorough visual inspection. But there are people who have pass the sniffer test with the remaining 2 cats in place.
Old Aug 4, 2006 | 02:04 PM
mudman's Avatar
From: Stop drag racing a rally car, and you'll be OK
Car Info: WRX STi
The up-pipe cat is only needed for a cold engine......as long as you keep your stock downpipe and swap it in when it comes time for smog then you'll be fine.
A gutted stock up-pipe will also pass ANY visual test because you can't see inside it.
The scooby medic is giving you bad advice. NEVER use an aftermarket up-pipe, because it has NO performance advantages over a gutted stocker, but will require many hours of labour to swap in the case of a state ref ticket.
A stock, gutted up-pipe can be bought on Ebay for $80, the guy that guts them even buys back your old one for $40 (get a tracking number to confirm he recieved it). Just do a search on eBay on the keywords "WRX gutted up-pipe".
In summary:
Stock, gutted up-pipe - undetectable, cheap, same performance
aftermarket up-pipe - easily detectable, expensive, same performance.
hope this helps.
Old Aug 4, 2006 | 06:40 PM
WRX409's Avatar
Car Info: 04 WRX
Thank you for your insight Mudman.
Old Aug 10, 2006 | 02:53 AM
03bluWRX's Avatar
Car Info: 03 WRX
not sure if it is the same guy or not, but the guy at nasioc(he was one of (???) selling them on ebay) stopped doing it.
Old Aug 10, 2006 | 10:34 AM
1neWRX's Avatar
Car Info: White 04 WRX
aftermarket uppipes are not that expensive. and to gut the stock you still have to remove it right? so while removing it you might as well install the aftermarket one. and either way you cant see it...
Old Aug 10, 2006 | 11:01 AM
DomozitoLK's Avatar
Actually there are hi-flow catted uppipes. Random Technology makes one.
http://www.randomtechnology.com/subaru.html
http://www.subarureview.com/showreview.php?id=1100
FYI
I'd never buy one...but they do exist. I got a Bosal uppipe. Has heatshields and all so it looks just like the factory one...except no cat.
Old Aug 10, 2006 | 11:03 AM
VRT Gump's Avatar
just buy an 06 and you wont have to worry about having a catted uppipe.
Old Aug 10, 2006 | 01:29 PM
mudman's Avatar
Car Info: WRX STi
1. Aftermarket up-pipes are far more expensive than the $40 it costs to get your stock pipe gutted
2. If you get a state ref ticket and the inspector knows his way around a Subaru turbo system he WILL see it.
In summary, A stock, gutted up-pipe is cheaper, better fitting, impossible to detect and provide the same performance on a VF series turbo.
Old Aug 10, 2006 | 01:31 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
id get a new uppipe before spending the day cutting all that stuff and out and inhailing it. sell the stock to someone else and let them do it
i found my catless aftermarket pipe for 50 bucks just make sure you install it right
Old Aug 10, 2006 | 01:37 PM
MVWRX's Avatar
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
...best option IMO is to find a used STi uppipe...
Old Aug 10, 2006 | 01:43 PM
DomozitoLK's Avatar
Thumbs up Bosal Up-pipe
I was looking for an STI factory up-pipe but all the ones I found were outside of California and had more surface oxidation than I was willing to accept, plus they wanted $125 shipped for them (or more). I thought that was outrageous as for a little more money you can get brand new aftermarket ones, not used-pulls.
At a glance the piece looks like a factory unit with heatshields et al, just no EGT bung as there is not pre-cat here. This is what I wanted, especially living here in California where we need to do visual smog inspections. This part should blend right in.
Old Aug 10, 2006 | 09:56 PM
WRX409's Avatar
Car Info: 04 WRX
Thumbs up
FYI
Thanks for the info I will be calling JSC speed soon to see
about those highflow catted uppipes.
freshrex
Mar 23, 2011 11:46 PM
-WickedRex-
Jan 5, 2007 07:19 PM
1sicwrx
Jun 10, 2006 07:32 AM
pleue
Apr 19, 2003 06:24 PM
pleue
Apr 18, 2003 04:41 PM
