Where is fuel pump?
Old Feb 2, 2004 | 05:26 PM
DrD's Avatar
DrD
Car Info: 2012 Legacy 2.5GT-L
The fuel pump can be accessed through a panel under the rear seat (as you suspected) - removal is pretty simple - disconnect the fuel line (make sure you de-pressurize the system first), remove the nuts holding it in place, then pull it out.
Old Feb 2, 2004 | 08:21 PM
Wingless Wonder's Avatar
Check out member wrXratd's fuel pump install. He has a wagon but the sedan is similar.
Old Feb 2, 2004 | 10:21 PM
Uncle Scotty's Avatar
It is accessed BEHIND the rear seat. The sedan has an access panel just behind the rear seat, passengers side.
Taking the rear seat out to remove and replace the fuel pump is the easiest way to do it, IMHO.
Old Feb 3, 2004 | 08:57 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
I did it without removing the seat, only because I couldn't quickly figure out how to remove the seat!
Old Feb 3, 2004 | 09:14 AM
koopatroopa781's Avatar
Car Info: 2002 subaru impreza WRX
you should also use a offset screwdriver to remove the cover, it makes it a lot easier. i also didnt remove the seat.
Old Feb 3, 2004 | 11:15 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Yes please depressurize the system. My friend found out the hard way in his Civic SI and fuel sprayed everywhere!! LOL
Old Feb 3, 2004 | 02:40 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
where do you depressurize the fuel system...
Old Feb 4, 2004 | 01:22 AM
Unscrew the gas cap before you start the job.
Old Feb 4, 2004 | 09:00 AM
From experience, starting the car and letting it stall after you unplug the fuel pump (and unscrewing the gascap) is NOT enough to depressurize the system. Trust me.
I don't know the correct way to REALLY do it. I've just gotten good at soaking up a jet of fuel!
drifter04
Nov 5, 2008 10:38 PM
iNfEk
Hawaii Classifieds
Jul 18, 2007 01:01 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
JohnB
Jun 30, 2003 12:14 PM
