Where to buy VDO gauge?
I have a little Christmas money that needs to be spent. Where is the best place to buy the VDO boost gauge? Also, is is better to get the copper tubing rather than the nylon?
Are there other parts that I need besides gauge, tubing kit, and mounting cup?
Pr0n King
Car Info: Turncoat Turbo
www.summitracing.com is where I got mine:
VDO-150121D - gauge
VDO-150851D - tubing kit
VDO-240016 - mounting cup
That's everything on the receiving end. I used a bunch of brass fittings from a local NAPA to get the sending side (off the BOV) set up.
__________________
VDO-150121D - gauge
__________________
If you have a local shop that sell VW air cool stuff, they usually have vdo guages. There are German made and I think Brazilian made vdo guages. Get the German made ones if you can but they'll be more expensive.
As far as copper tubing, it might be better but unpractical. Have you thought something else with a built-in boost guage. I have a Blitz t.timer with peak boost reading. It helps when you're tuning.
good luck...BlueMax
good luck...BlueMax
UnknownAlly
Oct 10, 2011 03:14 AM
sano.
Jun 14, 2006 01:36 PM
DomozitoLK
Jul 13, 2004 12:31 PM
