when to replace spark plugs?
Old Oct 30, 2003 | 02:00 PM
John #555's Avatar
Car Info: 02 WRX
Question when to replace spark plugs?
I'm long over due for new plugs (mileage-wise), but it's still running strong. how can i tell if i need to replace the plugs? any obvious signs?
Old Oct 30, 2003 | 03:33 PM
Wutzdatbehindu's Avatar
Car Info: 2002 Subaru WRX
And for that matter...where are they? DIY pics would be awesome! Thanks in advance!
Old Oct 30, 2003 | 04:15 PM
John #555's Avatar
Car Info: 02 WRX
scoobymods.com
at one point i started working on it, however, you really need proper tools to make the job easy.
Old Oct 30, 2003 | 04:17 PM
platypus's Avatar
Car Info: dangerous with a wrench
As far as do you need to replace them, you'll want to pull them out and have a look see to see if they're dirty. If you're going to go to that much trouble, I'd just replace them at that point.
:banana:
Old Oct 30, 2003 | 06:09 PM
NGK coppers are less than 2 bucks apiece, so replace them as often as you want. I recommend them for best power/knock protection. They typically last about 15k.
Old Oct 30, 2003 | 07:26 PM
John #555's Avatar
Car Info: 02 WRX
thanks for the tip. so, how long does it take you to replace them?
What happens if you use them for too long? - my initial question.
Old Oct 30, 2003 | 10:15 PM
You start having more difficult starts if you REALLY keep em for too long. Also, they affect your gas mileage eventually and even your throttle response...less spark=more fuel for same amount of combustion under clean spark.
Then again, that's just my common sense...if I'm wrong...WHOOP DEEEEEE DOOOOO...i'm sooooooooooooooo sorry!
Old Oct 31, 2003 | 09:13 AM
John #555's Avatar
Car Info: 02 WRX
i forgot to ask... would you happen to have the part#?
Thanks!
Old Oct 31, 2003 | 12:00 PM
BKR7ES-11
If you wear your plugs out, you get less spark, which results in hard starts, low mileage, loss of power, maybe even misfire CELs. Once you get the procedure down it should take you about 10-15 minutes to change them. Nothing difficult at all about it, other than the fact you need to pull your battery, washer bottle, and snorkus (lucky me- my SOHC heads have the plugs angled, so they clear the battery, and I don't have a snorkus anymore ).
Bagin,DVS
Mar 25, 2008 10:22 AM
Vizzionz
Apr 7, 2007 07:57 PM
DetailAddict
Oct 21, 2005 03:11 PM
ChronicSystems
Vendor Group Buys/Specials
Dec 4, 2002 09:53 PM
PimpWagon
Nov 25, 2002 02:33 PM
