when is the electric fan supposed to run?
Old Jul 10, 2003 | 02:48 PM
wizurd's Avatar
Car Info: WRX 02 Silver wagon
Ever since i have had the car........... i dont think i have ever heard the fan run after turning the car off while the engine is hot........... but if i put the key in and turn it to the 2nd position without starting the car the fan will turn off back on......... and turn the key to off the fan goes off............ arent these electric fans supposed to run all the time till its cooled off and not just when the key is turned............ is this normal??
Seth
Old Jul 10, 2003 | 03:33 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
no. The fans will run when the car is on electrically and when the temp is above 200F.
Old Jul 10, 2003 | 03:34 PM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
what he said, they will not run when the key is not in the "on" position.
Old Jul 10, 2003 | 04:04 PM
Jejunum's Avatar
or if the A/C is on i believe...
Old Jul 10, 2003 | 04:29 PM
but the a/c cant be on if the key isnt in the "on" position
Old Jul 10, 2003 | 05:27 PM
wizurd's Avatar
i would imagine if the fan is on with the key in the start position and you turn it to the off position and the fan goes off, then back to the start position the fan goes on, this cannot be correct right............ i was just wondering if everyone elses cars do this or not........... i dont want to be frying my motor if this should be corrected and im neglecting it
Seth
Old Jul 11, 2003 | 02:28 PM
wizurd's Avatar
does the consensus say i should except this as normal operation or bring it down to subaru for further inspection?
Seth
Old Jul 11, 2003 | 10:56 PM
iLoqin's Avatar
Car Info: Nadda
I don't think there is a need to take it to the dealer. Just be plain happy it's runnin', then you know your engine will be cooled down. I'd be worried if I never heard it...
Alliedforces86
Feb 20, 2010 10:22 AM
RALIWGN
Nov 24, 2009 08:23 AM
mattsn0w
Mar 15, 2009 07:05 PM
JDM SiR
Aug 5, 2003 04:24 AM
poppin fresh
Mar 11, 2003 04:43 PM
