Whats the deal with MBC
Old Apr 6, 2003 | 12:09 PM
EtchyLives's Avatar
Most MBC's are all the same. I would recommend a Joe P or Dawes device. Unless the MBC is total crap, or made by blind monkeys, it should work just as well as any other. Just MAKE SURE YOU GET A BOOST GUAGE TO GO WITH IT. And don't put it over 16psi unless you have engine management. The n00b has spoken.
-Etch
edit: Oh yeah, about the adjustment. Every MBC I have ever seen is adjustable. Usually there's a little twist screw on top that you turn to raise/lower the boost. Sometimes requires a screwdriver or wrench, but real easy to adjust, and so easy to install that I could do it myself without supervision.
Old Apr 14, 2003 | 06:54 PM
ride5000's Avatar
hackjar,
i'd be interesting in seeing a layout of your scheme. also, if you've got the part #'s, or whereabouts in home depot you found your brass valves, i'd be interested.
i'm also wondering if there would be interest in a GB of grainger 12vdc actuated solenoids. they go about 20 bucks, but they don't sell to the public (afaik)--you need to have a commercial account.
ken
Old Apr 15, 2003 | 11:06 PM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
do a search on nasioc for mbc. This has been discussed alot. The main problem with mbc's is partial throttle full boost. Meaning if you are giving 1/4 throttle you will have full boost. This is bad of course since the turbo is constantyl spooling and you will get REALLY high egt's. Also theres ball/spring vs bleed. I wont go into detail but to have a "safe" mbc peopel have used both combined. Or the ball spring type with a restrictor to bleed off excess pressure.
Old Apr 16, 2003 | 10:16 PM
P5Shawn's Avatar
Car Info: 2002 Mazda Protege5
A quick question about setting the boost level. Someone said to check the boost in 4th gear but at what RPM should you check the boost in 4th?
Old Apr 17, 2003 | 08:13 AM
dan avoN7's Avatar
when checking for boost you normally want to check for it in 3rd gear and go all the way to redline. This will give you an accurate reading of your boost. You might want to go test this oin freeway though because by the end of 3rd you will be going pretty fast.
Old Apr 17, 2003 | 02:43 PM
mmboost's Avatar
MBC are fine to use. I had one. You just need a boost gauge first and don't go stupid gung ho.
But, I'd recommend not wasting your time. Anyone who wants to have more boost and do it safely and really get the best bang for your work and $ eventually gets an EBC anyhow.
Save your $ and put it towards an EBC.
jason
FuturistiK_STI
Jun 30, 2011 08:45 AM
bartolommeff
Mar 22, 2005 04:25 PM
marinwood
Mar 2, 2003 08:28 PM
Zoeb2s
Feb 10, 2003 11:41 PM
