What is a turbo timer?
Old Dec 31, 2002 | 03:42 PM
Zoeb2s's Avatar
I <3 White Girls
a turbo timer is a device that times ur tubo...i.e. it lets the car run for 30 seconds to a minute in order to cool down the turbo. SOA says you dont need to time the turbo, but a lot of people do time it to be on a safe side.
Old Jan 2, 2003 | 04:07 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
Originally posted by WRX_RIFF_RAFF
just to add to that.
The reason to owning one though is to prolong the life of your turbo!!
When you are really on the car and spooling the turbo alot, of course it going to get really hot! (Exhaust Gases)
Well it is damaging to just shut your engine down and let your turbo cool on its own!
So they make these Turbo Timers, so depending on how you have it set in time! When you turn the key to off, the engine keeps running for your desired time to allow the turbo to spin slowly and cool down while you can walk away feeling better about your self. In all it will help your turbo last longer!
Its just a benefit to use it, not a requirement on a stock turbo car!!
no.....02BlackWRX had it right.
(from June 2001 TechTIPS published by Subaru for Subaru Technicians):
"2002MY WRX TURBO COOL DOWN PROCEDURE
FHI's posistion regarding this is that it is not necessary to perform a "cool down/idling" procedure, as was recommended with past turbo models. Our current 2.0L turbo engine has a far greater cooling capacity and, coupled with technology advances, makes this practice no longer necessary. This explains why information about cool down is not included in the 2002MY Impreza Owner's Manual.
The heat contained in the turbo charger will begin to vaporize the coolant at the turbo charger after the engine is stopped. This hot vapor will then enter the coolant reservoir tank which is the highest point of the coolant system. At the same time the vapor exits the turbo charger, coolant supplied from the right bank cylinder head flows into the turbo. This action cools the turbo charger down. This process will continue until the vaporizing action in the turbo charger has stopped or cooled down."
Granted, I would never run my car hard and then park it. I always take it easy for a few blocks before I reach my destination. This way all components have a chance to "cool down" to normal operating temperatures. Having a turbo timer won't hurt anything, except for the fact that you have to leave the car out of gear while unattendended.
Kean
UnknownAlly
Nov 4, 2011 10:54 PM
Sti"izzle"
Jun 6, 2006 12:21 PM
SUBY_6_STI
Apr 7, 2006 01:24 PM
Dirty Sanchez
Dec 28, 2005 02:08 PM
my25rs
Wanted
Nov 22, 2002 02:14 PM
