what parts to replace on a 2.0L WRX replacement?
Old Jun 28, 2011 | 08:22 AM
mattsn0w's Avatar
my motor recently started consuming more oil than usual and I believe it's time to rebuild the engine. i've put 170k miles on the car without much trouble, still on the original clutch. so on to my questions...
i'm looking to purchase a new 2.0L short-block from the dealer, and new heads and moving over the cams and valve. I am trying to find out what parts I should expect to replace since i'm basically putting in a brand new engine.
Here is what I have so far:
overhaul gasket kit (includes head gaskets and a bunch of other gaskets & seals)
water pump
timing belt
idler pulleys (1 &2)
timing belt tensioner
lighter crank pulley
oil pan pickup
ARP head studs
spark plugs
exedy streetlight fly wheel
act clutch
STi clutch line
newer TD04 turbo
new uppipe
I would greatly appreciate any info and tips the i-club community can share with me on getting this done successfully.
Thanks!
Old Jul 1, 2011 | 06:00 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Why not save $$$ and rebuild the existing block?
Old Jul 1, 2011 | 05:22 PM
mattsn0w's Avatar
time.
Me and my friend that are doing the work have little of it and both have babys at home. it's not much less money to rebuild, and more time once you factor in machine work.
Old Jul 1, 2011 | 05:51 PM
StealthMODE's Avatar
Car Info: @eatwithnaveed
why not just build it and get s 2.5?
Old Jul 1, 2011 | 10:20 PM
mattsn0w's Avatar
why wouldn't I have posted it to the EJ25T forums?
Old Aug 13, 2011 | 06:46 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
I just picked up a 2.0 short block from machine shop.
They put new rod and main bearings, piston rings.
Are you gonna geta new heads or rebuild old ones?
you should replace the motor mounts too since you have 170K on exicting ones and most likely they are blown
let us know how the build goes
Old Aug 13, 2011 | 09:20 PM
mattsn0w's Avatar
new heads and swap over the cams, valves, and springs and replace any of thvalves and/or springs that need it.
purchased STI group-N motor mounts as well. my mechanic friend will be back from vacation in a week or so and then we can finally get started!
Old Aug 13, 2011 | 09:56 PM
iClub Silver Vendor
No new pistons?
mattsn0w
18
Apr 18, 2007 11:03 PM
wardo
Jun 2, 2003 09:56 AM
bedweaselwrx
May 19, 2003 01:40 PM
UniquesubieWRX
Apr 29, 2003 10:47 AM
nehusker
Jan 16, 2003 02:25 PM
Top
