What is octane
Old Sep 6, 2004 | 08:22 AM
Full_Clip's Avatar
Car Info: 1991 Accord
What is octane
Since a search on octane normally turns up incorrect or partially incorrect answers, plus people still post questions about octane boosters without a clear understanding of octane, he has found a good definition that will (hopefully) explain things to everyone.
Originally Posted by Organic Chemistry, 5th ed, Wade Jr
In addition to being volatile, gasoline must resist the potentially damaging explosive combustion known as knocking. The antiknock properties of gasoline are rated by octane number that is assigned by comparing the gasoline to a miture of n-heptane (knocks badly) and isooctane (2,2,4,-trimethylpentane, which is not prone to knocking). The gasoline being tested is used in a test engine with variable compression raio. Higher compression ratios induce knocking, so the compression ratio is increased until knocking begins. Tables are available that show the percentage of isoocatne in an isooctane/heptane blend that begins to knock at any given compression ratio. The octane number is assigned to the gasoline is simply the percentage of isooctane in an isooctane/heptane mixture that begins to knock at the same compression ratio.
A theoretical tank of gas that is 100% n-heptane would have an octane of 0. Conversely, a tank of isooctane (2,2,3,-trimethylpentane) would have an octane rating of 100.
Full_Clip has lots of gas.
rota wheels wrx
Sep 6, 2004 04:57 AM
Need4speed
Mar 29, 2004 11:31 PM
meebs
Dec 11, 2002 07:06 PM
gpatmac
Nov 26, 2002 03:56 PM
