What (mod) next?
Old Jan 24, 2004 | 03:47 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
What next?
Hey guys,
Below is a list of mods I have on my car. I used to have a VF34 setup and am still thinking about doing another one, but for right now, I'd prefer to stick with my stock turbo. Tell me what else I can do to increase power besides a turbo upgrade.
- Vishnu Catless Uppipe
- Vishnu Catless Downpipe
- Vishnu Dual Tip Non-Signature Exhaust (1 Cat)
- Vishnu Main Power Pulley
- Vishnu ECUtek Stage 1 Reflash
- Samco Intercooler Hoses
- Samco Radiator Hoses
- Samco 9 Piece Hose Kit
- Cusco Water Spray Controller
- STi RA Spec C Water Tank
- Pivot Water Spray Nozzles
Chris
Old Jan 25, 2004 | 08:54 AM
AWD 20T's Avatar
Oh come on guys, I know some of you have suggestions...
Old Jan 25, 2004 | 10:15 AM
meilers's Avatar
t\/\/0 819 b0+Tl35 4 N4\/\/5
(courtesy of the l33t-speak translator)
Deuce big-*** bottles o' N-O-****in'-S
(courtesy of the jive-speak translator http://www.ighetto.com/html/jive.shtml)
C'mon, you've seen the movie, you're car can't possibly be fast until it has a magic red button on the steering wheel that somehow distorts time and space itself when it is pressed.
[note: the above is intended as sarcasm, and is in no way to be taken seriously for any reason]
All kidding aside, it sounds like you're pretty much done with that engine unless you want to move to the Stage 2 reflash (which doesn't seem like a good idea unless you have access to 92-93 octane). I know you asked in the engine forum, but have you also worked on your suspension/shifter/steering components? Having a raging beast under the hood means nothing if you can't keep it on the road and you are producing well past what the original WRX chassis was designed to control...
Old Jan 25, 2004 | 10:51 AM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
How about adding a Turbo inlet hose? Perhaps a little larger TMIC may help a little.
You could start working on other area's of the car like braking and handling as this will make you faster in general.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Jan 25, 2004 | 11:17 AM
AWD 20T's Avatar
Suspension is as follows:
- JIC Magic FLT-A2 Coilovers (Old Spec)
- Cusco Front Strut Bar (Titanium)
- Cusco Rear Strut Bar
- Cusco Front Sway Bar
- Cusco Rear Sway Bar
- Cusco Rear Triangle Bar
- Perrin Endlinks
Old Jan 25, 2004 | 01:44 PM
oldmansan's Avatar
Sounds like
money is no object, so why not put in a Ver 8 STI motor? And of course as mentioned above, the NAWS! I'll probably get flamed, but I am on the stock turbo with a FMIC and header, and am running with STIs at the track. I do have a ported and polished VF34 waiting to go in (waiting on engine management). One other thing, titanium is flexier than aluminum, your front strut brace (whick is arguably not needed) probably isn't doing much.
San
Old Jan 25, 2004 | 06:45 PM
AWD 20T's Avatar
Money is an object, that's why I'm holding off on the turbo upgrade.
Old Jan 25, 2004 | 07:10 PM
Former Sponsor
Perrin Turbo Inlet would be good for the $$'s
Actually a complete turbo swap can be done for relatively cheap, Chris you know we would work you a deal mate!
Mike
Old Jan 25, 2004 | 11:15 PM
oldmansan's Avatar
You said for "right now"
you'd prefer to stick with the stock turbo. I thought that since you already had a VF34, you wanted faster spool (stock turbo). With all the mods you already have, and some of them bordering on bling (hoses), I wasn't sure what direction you where headed.
San
Old Jan 25, 2004 | 11:21 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
more info on that new garret turbo plz....sorry to hijack...
Old Jan 26, 2004 | 05:33 AM
DOHCammin's Avatar
Car Info: 05 CGM FXT STi
port and polish the stock turbo...pretty good gains and relatively inexpensive (+/- $500)
Old Jan 26, 2004 | 08:37 PM
awns729's Avatar
Car Info: want a WRX
^agreed! defininitely worth it, especially when moneys a factor
Old Jan 27, 2004 | 06:45 PM
AWD 20T's Avatar
I guess I'll look into that, but for right now, I think I'll go with the turbo inlet and maybe some motor/tranny mounts, and hookup my water sprayer!!!
