what is the factory boost on a wrx??
Old Aug 10, 2005 | 06:23 PM
scoobie555's Avatar
dealer said 8-12 psi wtf. thats a wide range and sounds wrong.
Old Aug 10, 2005 | 06:33 PM
lastlaugh's Avatar
14.5 if I ain't mistaken.....
Old Aug 10, 2005 | 07:55 PM
MO REX's Avatar
Car Info: 02 PSM WRX
13.5 psi
Old Aug 10, 2005 | 11:03 PM
Me&05WRX's Avatar
Car Info: 2015 STI
Originally Posted by MO REX
13.5 psi
+1 to that... I read it from the WRX brochure.
Old Aug 12, 2005 | 10:08 AM
blue blurr's Avatar
13.5 unless your catless.
Old Aug 12, 2005 | 01:07 PM
meilers's Avatar
That may be the brochure answer, but it actually varies widely from car to car and in different climate temps. Not a day goes by that I don't hit 14.2 PSI in my stock 02 WRX, and I've seen 14.5 and 14.7 pretty regularly if I'm driving in cool weather with the A/C off. Meanwhile, a friend of mine with a WRX a month younger than mine peaks out at 13.3.
Old Aug 12, 2005 | 03:47 PM
MO REX's Avatar
+1. I should have said 13.5 psi is the target that Subaru shoots for.
Old Aug 12, 2005 | 04:08 PM
turbo tecnica's Avatar
Car Info: '02 Stage 2 WRX
What does it change to when you go catless? I'm seeing about 14~ psi right now regularly, and will be putting an HKS turbo-back on within a couple weeks.
Old Aug 12, 2005 | 04:41 PM
blue blurr's Avatar
Well im around 15psi with stock tune and a catless exhaust. When i was seeing less then that with my stock exhaust.
Old Aug 12, 2005 | 09:26 PM
Ah, I will have to check for a boost increase when I put the exhaust on.
Old Aug 12, 2005 | 11:16 PM
YOURE ALL WRONG!!!!!!!!
it depends what gear your in
the dealer is correct
Old Aug 13, 2005 | 12:01 AM
meilers's Avatar
The customary gear for measuring boost is 3rd gear, same gear used on the dyno.
thespence
Mar 13, 2012 06:54 PM
dpulse2930
Feb 23, 2011 07:38 PM
MO REX
Apr 10, 2004 02:21 PM
