what to expect for damage
Old Nov 19, 2003 | 04:19 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Should have asked questions before buying, hope you got this car cheap.
If the cam sprockets are damaged as you describe it's very likely the valves are bent and there may be damage to the pistons as well. The heads would have to be removed to inspect the engine internals and determine the extent of the damage. Depending on how bad it is you may be better off finding a replacement motor.
Then there is also the matter of body damage and whether the frame is affected and to what extent. Some types of frame damage are unsafe and/or not cost effective to repair.
Before you go too far with repairs and expenses evaluate the car completely, and determine if it's really worth fixing and if it'll be structurally sound and safe once done. Compare the total cost and effort of the repairs against that of buying a good used car that you can just drive.
If it turns out to not be worth repairing you still have the option of parting out whatever is good on it to recover some $$.
Old Nov 21, 2003 | 06:16 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
These cars have plastic cam gears?
Old Nov 24, 2003 | 10:52 PM
That subframe is partially for stiffening, and partially for crash safety. If the latter wasn't a factor I would recommend removing it... but alas, it needs to stay.
cmb
May 30, 2003 11:03 PM
Happy Ending
Feb 26, 2003 07:43 PM
Astacun1
Jan 30, 2003 09:55 PM
spdkills
Jan 29, 2003 02:53 PM
AWDball
Dec 17, 2002 08:26 PM
