What can I do to get high top speed?
Originally posted by Damaged Goods
Lower it as low as you can go so there is less drag
remove the mirrors so there is less drag
remove the spoiler so there is less drag
really skinny tires so there is less drag
get a FMIC so you can ditch the hood scoop for less drag
take duct tape and cover all the body lines and contours on the front bumper, esp fog light recesses, for less drag (you laugh, but it was done in Car and Driver when the new body style mustang came out in 94 so they could hit 140 in the stang)
after all that, go to a wind tunnel, find out your Coefficient of drag, calculate how much Hp you need to go 200, build a motor with that much Hp, get custom gears made to match so you are at max Hp Rpm at whatever 200 Mph would be......
Or for $10,000 get a used Suzuki Hayabusa, mod it a little and enjoy the ride
:banana: :banana:
ive hit an indicated 140 and that was fast enough for me in a car
:banana: :banana:
Originally posted by nic3krnnamja83
sounds like a lot of work
that was the point!!!a Wrx really isnt a top speed kind of car, if you want high top speed, you need to do a lot of work and spend a lot of money, or start with a different car......
Car Info: Corvette Z51
no! i want it. detemrined to outrun cops. heheHHAhAHAHAHa
Unless you can outrun their helicopters on your death mission to the Mexican border
yes u can, if you watch the news, they are proposing a law to end high speed chasing over 100. so by law if it passes u can go over a 100 and they have to stop chasing you. so if u can reacha 100 before mr heli comes i think ur ok.
actually car mass has little to do with top speed.
remember at top speed there is no more acceleration taking place.
wheel horsepower, and aerodynamic drag are all there is to it!
ken
ken
NEVAR EVAR!!!! :banana:
I remember reading in a magazine several years back about an attempt to make a Corvette do 200 m.ph. Even with the aerodynamics of the Corvette body it was figured that at 199 m.p.h. it would take 88 more h.p. to do one more mile per hour. I very much doubt that someone in a beefed up Camaro managed 220 unless he was running maybe 800 h.p. and had ***** so big he needed a wagon to carry them.
Originally posted by awns729
I think mass does have a little to do with it. If a 5000+ lb car with 227 horses is trying to get to 140, its probably not going to happen.
Car Info: 1973 Huevo Ranchero
Originally posted by wrx ish
do you guys realize that the gearing on the 6 speed makes the car top out at around 130mph?
That law has been passed here in CT already. 80mph though and the cop has to stop the pursuit.
