What is the baddest turbo for an EJ20 engine out ther?
Old Dec 14, 2004 | 03:13 AM
Lurk's Avatar
Photoshop.
Old Dec 14, 2004 | 10:07 AM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
I think its real
Old Dec 14, 2004 | 10:33 AM
meilers's Avatar
It is real; turbos that size are common on commercial-class diesel engines, like 1800hp gravel loaders and 18-wheelers.
I watched an episode of Junkyard Wars where they turned a turbo as large as that one into a rocket engine...
Old Dec 14, 2004 | 05:09 PM
2amWagon's Avatar
Car Info: 03 PSM Wagan
I got your "baddest Turbo" right here...
Attached Thumbnails What is the baddest turbo for an EJ20 engine out ther?-turbo21.jpg
Old Dec 14, 2004 | 06:43 PM
hahahah
american gladiators
the exhuast would have to come forward from the heads instead of back on that car
Old Dec 15, 2004 | 02:23 AM
GO24JUNIOR's Avatar
Car Info: Subaru WRX 2002
That's interesting stuff you guys but like I asked before that Greddy TD06 20G kit that is on the Gruppe-S website that I linked to above will that fit my car and bolt right up yes or no and what kinda horsepower can I expect from it with all the rest of the fixing that would be needed?
Old Mar 14, 2005 | 06:59 PM
dubRexer's Avatar
Car Info: white/gold sti
Talking duuude
that turbo set up would definitely get you into the 12's. if it is a said bolt on for your rex it should bolt right where the stock turbo goes. your best bet is to contact preston or gary at gruppe-s you can do it thru their website or here in i-club. gruppe-s is the shiz. as far as building the rest of your car: do you have to? - no. will you blow up your daily driver? - yes. a daily driver with a lot of power is almost an oxymoron but if you do it right i.e. build the motor, upgrade the tranny, get a professional tune (i.e. ecutek) and you should be o.k... but seriously - this is the realm of aftermarket parts and huuge power anything is possible so good luck and if it does blow which is probability.. i hope you got deep pockets cuz you gotta pay to play
sorry for rubbin' it in bro and best of luck - check out deadbolt speed they have great turbos at unbelieveable prices with free rebuilds for life on some turbos (check out the website - www.boostplanet.com)
peace.
Old Mar 14, 2005 | 08:55 PM
jdepould's Avatar
Car Info: 1990 thing
you're about 3 and a half months late bud
Old Mar 15, 2005 | 10:34 PM
schafer's Avatar
Car Info: 03 black wrx
Ok guys what about a 16g? Will this provide me with decent power but keep my engine from blowing? And what about injector size with a 16g turbo? Should I just run pinks or should I go much bigger?
Old Mar 15, 2005 | 11:46 PM
dubRexer's Avatar
turbo, etc..
the 16g would definitely be a nice change from what you have now. sti pinks should be fine for you since they can take around 350-400 horses. you need a fuel pump, you might consider upgrading the fuel rail. then you'll need a tune or some kind of ecu 'link.' it sounds like you have everything else.. good luck.
Old Mar 16, 2005 | 06:52 PM
schafer's Avatar
https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/deadbolt-speed-td05h-16g-modified-straight-inlet-standard-90-degree-inlet-92833/
ted1186
Forester General
30
Sep 9, 2012 10:17 AM
krzyxrevver12
Jun 24, 2007 01:33 AM
IS2Scooby
Jun 29, 2003 02:43 AM
JSTTURBO
Dec 29, 2002 01:30 PM
