weird noise ..
Old Nov 27, 2004 | 03:30 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
weird noise ..
okay so, i think i know what the problem is but im not sure. whenever the car is at a stop. and i have the airconditioning on. there would be a rubbing sound ... and also a whistle sound like air flowing through a tube back and forth.... this just started happening when i installed my perrin lightened crank pulley ... so i think the pulley is the cause .. but is it just a sound or is it actually harmful to my car? .. and if it is harmful .. how can i fix it? thx for the comments
Old Nov 27, 2004 | 03:39 PM
New2MeSuby's Avatar
Car Info: 2007 Mazdaspeed 3, Black, 6spd
I would take the pulley off and just double check. If its under warranty they can't not fix it then.
Old Nov 27, 2004 | 03:59 PM
HomerJay's Avatar
Car Info: MY00RS25
Make sure your pulley is tightened to the correct specs
Old Nov 27, 2004 | 04:59 PM
Wingless Wonder's Avatar
Does the sound go away if you turn off the air-conditioning? If so, what you may be hearing could be the sound of the a/c clutch engaging (mechanical sound that could be described as 'rubbing') and the various other noises that a/c makes when it circulates the refrigerant through the system.
Other than that, it's hard to diagnose sounds over the internet.
WyldKardzWRX
Jul 23, 2003 10:31 AM
WrxKiDD
Jun 11, 2003 11:27 PM
Aussie Rex
May 12, 2003 10:47 AM
ges311
Apr 3, 2003 07:00 PM
-LD
Feb 6, 2003 10:58 PM
