Water temp Gague
Old May 1, 2003 | 09:09 PM
t-wrexxx's Avatar
Question Water temp Gague
I am going to be installing an Autometer carbon fiber water temp
gauge into my car. Is it a better idea to tap into the ECU or
should i install the temp sender etc.? Will one give a more
accurate reading than the other?
Old May 2, 2003 | 11:59 AM
t-wrexxx's Avatar
Im in a 02 WRX and already have the EGT, Boost, oil temp, and AFR gauges. Yes, the car already has a water temp gauge, but the factory has it calibrated so the needle won't move unless there is a extremely high temp. The actual temp can rase/fall by about 40 degrees withou the stock gauge showing a difference at all.
Old May 2, 2003 | 12:09 PM
Mulder's Avatar
Car Info: 02 WRX WRB
You can't tap into the existing temp sensor without affecting the readings. It would be necessary to add a T fitting and install a second sensor for your gauge.
Old May 5, 2003 | 09:08 PM
t-wrexxx's Avatar
Ok. Being the dumba$$ that I am, I tried to tap into the coolant temp wire on the ECU. DON'T DO THAT! Got an extremely hot reading (close to 250 deg.) and the engine fan wouldn't stop running. Oh yeah, CEL too. After disconnecting everything, the light went off and the car runs fine. Just a word of warning to you guys.
Old May 6, 2003 | 02:49 PM
Mulder's Avatar
Told ya
Old May 6, 2003 | 03:24 PM
BlingBlingBlue's Avatar
Talking
Originally posted by Mulder
Told ya
Dude, mulder is wise!
Island Style
May 26, 2006 08:59 AM
GasPipe DreameR
Wanted
Apr 27, 2004 08:13 PM
bambams247
Aug 21, 2003 08:34 AM
fast legacy
Jun 27, 2003 10:35 AM
twistedsymphony
Jan 8, 2003 09:39 PM
