wastegate
Old Apr 15, 2004 | 11:51 AM
EVOKILA1's Avatar
Car Info: 03 wrx
Lightbulb wastegate
when wastegate open
does that mean turbo will stop boosting up and maintain the boost level right at when wastegate open.?
or something else.?
tks you
Old Apr 15, 2004 | 02:20 PM
esracer's Avatar
Car Info: 2002 Honda S2000
I think this is the way the wastegate works:
The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses the boost pressure. If the pressure gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down.
if you have anymore questions like this or about how anything else works check out,
www.howstuffworks.com
pretty interesting site!:banana:
Old Apr 15, 2004 | 09:43 PM
EVOKILA1's Avatar
Car Info: 03 wrx
i have profec b 2
but my boost will drop as soon as the level i set wastegate open.
shouldn't it just maintain the boost level.?
so now i get the boost up n down at all time...
any cue.?
tks alot
Old Apr 16, 2004 | 11:26 AM
yamatodamashii's Avatar
Car Info: s2
ever heard about running a car with an open wastegate???i too am not too sure on how this is suposed to werk, but a friend of mine that owns a RX7 runs his car with an open wastegate....and if you would like to know about disturbing the peace, MY GOD...(i kno rotorarys are loud, but this was insane). if i could get a video clip on his car, ill try to get it up.
Old Apr 16, 2004 | 04:57 PM
EVOKILA1's Avatar
Car Info: 03 wrx
so wastegate open means no more boosting up
and going all the way down to stock boost level
or it maintain?
Old Apr 16, 2004 | 09:09 PM
Mister 2's Avatar
That's an external wastegate that dumps to atmosphere instead of going thru the exhaust. It can be done with an internal wastegate too but would require modification to the turbo exhaust housing and a custom downpipe.
Old Apr 16, 2004 | 09:11 PM
Mister 2's Avatar
Originally posted by EVOKILA1
i have profec b 2
any cue.?
tks alot
What other adjustments can you make with the profec b? Does it have a "gain" adjustment? What boost level are you trying to get too and is your boost level surging back and forth?
Old Apr 16, 2004 | 09:52 PM
snicklous's Avatar
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
a waste gate takes takes the exhaust gas that is not used and dumps it.
nallen316s
Oct 6, 2014 11:54 AM
hey1230000
May 19, 2010 07:27 PM
scby blu
Jan 14, 2008 09:37 PM
xs_wrx
Feb 27, 2006 06:27 PM
ImprezaRSX
Dec 4, 2002 01:34 PM
