Vishnu or Turbo Xs TMIC
Old Jan 1, 2004 | 05:08 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
I prefer the TurboXS hyperflow unit myself, it's extremley well made and fits really well. Matched with a vf34 or similar is a hard setup to beat for the fast road setup.
I also think that FMIC's suffer far less from heat soak than TMIC's and that once the car is moving the performance difference between the two is night and day (you can't beat the air forced into the FMIC while moving).
FMIC's will add lag somewhat due to the pressure drop caused by the piping lengths but when used with a matched turbo this really is not very noticable at all and again once the car is rolling you'll appreciate the FMIC more and more.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Jan 1, 2004 | 05:27 PM
gpatmac's Avatar
San,
I am completely satisfied with my PWR TMIC. I feel that at the power I'm producing right now, it is all I need. Talk about cool. After a pass at HRP (I'm in Hawaii, too) or the heat ended at the trackday, the IC was barely warm.
Once I start to upgrade anything to do with power, then I think I might start to take a look at a FMIC, but with the stage 4, the TMIC is all my car needs.
Old Jan 3, 2004 | 12:56 AM
r8c3w1tm3's Avatar
well i wanna know who has used the turbo xs tmic, or the vishnu tmic, and can you tell me what your experience with the i/c, thanks for the other replys, but i would like to know which of the two are better....
Old Jan 3, 2004 | 04:12 AM
DriftinS14's Avatar
Car Info: 02 WRX, 06 A3
By design a TMIC set up is more efficient then a FMIC. One problem that wasnt mentioned yet with a FMIC is on the cold section. After the air charge is cooled generally with a FMIC it has to travel through a few feet of piping which is hot to get to the throttle body. During this trip the air charge heats back up. With the stocked designed TMIC the air charge travels an entire fraction of an inch which means no time for the air to warm back up, since your always moving while your boosting, heat soak for the TMIC (when using the turbo heat sheilds) isnt an issue. And oldman..... that paint or coating on your FMIC is hurting your heat disapation...
_justin
Old Jan 3, 2004 | 08:46 AM
Former Sponsor
_justin
You would have to have extreme underhood temps for constant periods for this to happen and we have never seen this happen in such a way that it heatsoaks the air coming in, this would only happen until the car gets underway which matters not seeing as neither a FMIC or TMIC is pulling in air at a stand still.
Like I said we prefer the TMIC's on cars with most of the bolt on turbo's, seems a much better matched combo to us.
I have personally installed and driven both the TXS unit and the Vishnu, my preference is the TXS one.
Mike
(510) 487-4447
JDMGC8
May 29, 2009 08:07 PM
blinguskahn
Oct 8, 2005 10:47 AM
blk rex wagon
Feb 2, 2005 04:16 PM
mysube97
Jan 14, 2004 05:52 PM
David@VISHNU
Dec 10, 2002 07:40 PM
