vf34 with intake
Old Jul 16, 2008 | 09:41 PM
freshrex's Avatar
Car Info: white 03 wrx
vf34 with intake
hey guys im installing a vf34 turbo on my 03 wrx right now. what im installing includes: vf34 turbo, sti injectors, 255 pump, perrin TMIC, perrin turbo inlet hose, and an spt intake. I have heard that a lot of people stick with the stock airbox because it flows well enough. Even if there is no difference between the stock and spt performance, i'll probably install the spt intake for the sound and clean look when you pop the hood (no big black plastic intake scoop). Is there any reason i SHOULDNT install the spt intake???
Old Jul 16, 2008 | 09:43 PM
VRT MBasile's Avatar
If you want an SPT intake, then install it. It isn't bad for a hot air intake.
That being said, do you have a V2 Accessport? If so you could NOT install it, cruise around and watch the intake temp gauge on the AP, then install the SPT and do the same thing.
Old Jul 16, 2008 | 10:07 PM
screw it you bought it you are this deep already
Old Jul 16, 2008 | 10:53 PM
DemonPossessed's Avatar
Car Info: 05 wrx
I'm running an spt intake with my vf-34. I have a very similar setup.
It runs just fine together.
if you want to look at my dyno chart click on the link below
https://www.i-club.com/forums/showth...89#post2259689
remember my car has a catted downpipe.
Old Jul 16, 2008 | 11:46 PM
03_Impreza_Al's Avatar
Just run the stock since those SPT intakes aren't CARB legal.
Old Jul 17, 2008 | 12:03 AM
darkonion's Avatar
Chicks dig me. April Fool's!
Hmmm... I thought they were CARB legal.
https://www.subarugenuineparts.com/p...oducts_id=1075
Old Jul 17, 2008 | 12:21 AM
AUDP (Another Useful Darkonion Post)
Old Jul 17, 2008 | 12:28 AM
darkonion's Avatar
No problem.
Old Jul 17, 2008 | 12:29 AM
darkonion's Avatar
You're Welcome!
Old Jul 17, 2008 | 01:35 AM
freshrex's Avatar
am i going to have any tuning problems with my vf34 with the spt intake vs. the stock intake??
Old Jul 17, 2008 | 07:34 AM
problems? No, but it'll be sucking in hot air which isn't optimal for performance.
Also, you will need to get a custom tune as the OTS Cobb map (if you have an accessport) doesn't support any intakes (unless they've changed since I last looked).
Old Jul 17, 2008 | 08:00 AM
mhmm last I heard they weren't being carb'd anymore. Guess i'm wrong there thank you.
But i'd still rather run the stock airbox than the SPT intake.
Old Jul 17, 2008 | 08:05 AM
aftermarket intake is pointless unless your planning on going like 350whp+.. the aftermarket ones heat up faster and take longer to cool down.
CarbonRust
Aug 17, 2009 10:41 AM
JRsWRX
Jul 27, 2007 06:59 PM
REXX13
Feb 9, 2006 11:40 AM
IMPBOY
Subaru OEM Parts For Sale
Mar 20, 2003 05:33 PM
RyanH
Feb 19, 2003 05:37 PM
